Question about Car Audio & Video
How to bypass parking brake on my genie 5519 forklift
  • 109 Answers
SOURCE: bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
Posted on Jun 06, 2008
j_del
  • 1586 Answers
SOURCE: bypass the parking brake on the vm9022
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 23, 2008
SOURCE: how do i bypass the parking brake switch in order for my video to play
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Posted on Sep 19, 2008
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Posted on Nov 16, 2008
Shadowmaru
  • 33 Answers
SOURCE: parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Posted on Feb 11, 2009
Daewoo forklift D30s wont start
Hmm, Shifter in Nuetral or park? Parking brake fully engaged?
Seatbelt on ? and LP gas tank on?
Cheers
Aug 22, 2014 | Electronics - Others
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
How do i bypass parking brake so i can watch movies
There is a parking brake switch lead that goes to the unit. You need to permanently ground it to bypass the safety feature.
Apr 28, 2009 | Car Audio & Video
No brake pressure Cat t50d forklift.
thottle linkage on t50d catipiller forklift anyone know how it goes on
Mar 25, 2009 | Caterpillar American Construction...
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Parking brake bypass
apply 12v positive to the wire to bypass the parking brake
Dec 12, 2008 | Jensen VM9510 Car DVD Player
Bypass the parking brake
forum.ecoustics.com/bbs/messages/4/338612.html
Jul 31, 2008 | Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
Parking Brake Bypass
I know my PLTS75 when we hooked it up. you connect the brake wire to the negative pole to bypass that
Mar 28, 2008 | Pyle PLDF7IN Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
