Question about Exercise & Fitness
Treadmill belt stopped
I recently moved my treadmill upstairs and had to take it apart. since re-connecting and reasembly the belt has stopped working. i switch it on and display is fine everything works even incline but the belt dont. it displays for 16 seconds as if it is running and then stops. cant hear any unusual noises and no funny smells ect. i'm sure i've put it back together properly??
  • Anonymous Mar 16, 2014
    Just walking belt stop not the display
  • Anonymous Mar 31, 2014
    Was running on it and it just stopped the display board is coming on but no movement on the belt
As soon as i press the speed button on my weslo m5 the belt seems to jolt forward then stops and everything goes off can anybody help on wot this problem could be
Posted on Aug 06, 2009
    New Friend:
  • 64 Answers
Double check all your connection. Check to see if you may have pinched any wires. Also check to see if you have accidently unplugged or pulled a wire loose. If that's not the case it sounds like a lower board issue.
Posted on Jul 27, 2009
Golds gym treadmill 420 belt will not move but panel works and elevated.
hi Mary.
If you flip on the switch, set the speed and nothing happens, your treadmill is an unhappy camper. Troubleshooting involves putting on your inspector hat and taking a tour of the belt. You may have to proceed to the console if that doesn't solve the matter. Belt Tension If the belt is too tight, it could cause enough tension that the motor can't turn the belt. This is most likely the cause of your belt not moving if you recently adjusted the belt tension due to slippage. Lift the edge of the belt. If you can't raise it at least 2 to 3 inches off the walking deck, the belt is too tight. Follow the directions in your owner's manual for loosening the belt. You will need an Allen wrench to loosen the rear roller adjustment bolts.Belt CenteringA treadmill belt can shift to the right or left over time. If it shifts enough, this may cause the belt to stop moving. Stand at the back end of your machine and inspect the belt. If it has shifted, you will need to center it by turning the rear roller adjustment bolts. These bolts adjust both the tension and the centering of the belt. Follow the instructions in your owner's manual that explain which of the two bolts you need to tighten or loosen to shift the belt back to the center.Console WiresHorizon Fitness recommends checking the console wiring if your treadmill belt doesn't move. The console wire connects to the main wire that runs down the inside of the treadmill upright to the motor board. Make sure the connection between the two wires is secure. The connectors usually snap into each other. Disconnect and reconnect the wires. Make sure the wire that runs through the upright isn't pinched or twisted.Additional Options If the troubleshooting does not get the belt running again, you may have a tight motor belt or a bad motor. You will need to remove the motor hood to access these parts of your machine. If your treadmill is still under warranty, contact the manufacturer for a professional repair. You may void the warranty if you attempt to work on the motor yourself.or read up some more at this link. Golds gym treadmill 420 belt will not move Google Search
Dec 12, 2017 | Exercise & Fitness
Acd3 treadmill belt wont move
hi There.
How to Fix Treadmill Belt That Won Move
or this one.
Acd3 treadmill belt wont move Google Search
Dec 16, 2017 | Exercise & Fitness
STAR TRAC 3500 SERIES ERROR EL4
1) Run the software calibration for easy diagnose and troubleshooting and fix. it
2) tight very well all connectors, and clean
3) Adjust the REED switch, see the diagram , clean and tight the connector very well.
God bless you
Jun 19, 2012 | Startrac Fitness Products StarTrac 3500...
Healthrider 500sel
B) Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank
down the belts and on treadmills, tighter is not necessarily better. The tighter the belts, the more the drive system has to work to keep
everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3" without
straining. Tighter belts should be loosen but make sure you don't create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating
position. Loosen the belt if too tight. Make sure to test for slipping
and if it does with the proper tension, replace the motor belt.
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
sincerely.
E. CUADRA
Oct 30, 2011 | Exercise & Fitness
Need to dismatle to move and can't
There are a lot of different treadmills and stairways that require specific solutions, but there are some general solutions.
You say you can't disassemble it, so try forearm forklifts, they can make a 2 person lift very manageable. Also if you have a large piece of cardboard (and once again, 2 strong people) the cardboard can be used to both provide a surface that will slide up the stairs and distribute the weight over a larger area, so you can actually put it on it's side without causing damage.
I've used this technique and it works with a little caution and muscle.
Oct 17, 2009 | Exercise & Fitness
Star Trac TR4500 Treadmill. Need help connecting the display
I recently took mine apart if you still need the exact details.
Jan 17, 2009 | Startrac Fitness Products Star Trac 4500...
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
465 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
