Question about Microwave Ovens
Thermal cutout MH7135XEQ0 microwave. Base cutout bridged. Nothing. Inner cabinet cut out behind a black cover behind vent panel. I cannot see how access to the switch. Can you help please? Thank you.
MicrowaveSvc
  • 9086 Answers
SOURCE: display shows nothing, microwave cuts off
We repair these control units for $39.95 nationwide. Usually a new one is not needed.
We have info on our service, plus critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 22, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: CFMV145--thermal Cutout Question
On this model, you can find the wiring diagram and exploded views at this site http://www3.sears.com (the 3 is correct)
In fact, the diagram you need most is here:
http://www3.sears.com/Paul/Leadimage.asp?productTypeID=0123245&brandID=1428&modelDesc=FRIGIDAIRE/MICROWAVE&modelNumber=CFMV145BC1&documentID=R0212007&documentTypeID=PLDM&documentClassCode=PV&titleType=WIRING%20SCHEMATIC&titleID=00006&
The hood TCO (normally open) has grey and red wires on it going to pins 7 & 5 of connector CO 02 on the circuit board.
The other TCOs should read normally closed.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 27, 2008
  • 43 Answers
SOURCE: Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Posted on Feb 01, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: i have an magic chef mvp V microwave and have just
Consult your installation instructions for that information.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
We're happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
Posted on Jun 05, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: I need to replace the
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at
http://www.microwavedisplay.com and swing it down, but without disconnecting the wires.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
They're our favorite supplier.
Posted on Aug 23, 2010
Where is the fuse box?
If no power fuse behind panel but may be thermal switch behind top vent remove and you can see it 2 black wires the spade may need to be tighten.This is the fire safety thermal. Test for 110 volt across to test.
Sep 30, 2014 | Samsung SMH1816S Microwave Oven
How do you get to the fuse when the unit is fixed under the cabinet.
If your oven is dead (no signs of life at all) it may be a blown fuse or one of the thermal cutouts / thermostats may be defective.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
here.
Accessing the thermal cutouts for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jul 09, 2011 | GE JVM1440 Microwave Oven
We have a r-1406 power to outlet nothing at microwave is ther a fuse or reset in machine
No reset, and if it's totally dead, it may be the fuse, the magnetron's temperature fuse, or the cavity thermal cutout.
We have the service manual and have uploaded it to our site here to help you.
The fuse should be accessible just behind the grill.
At our Web site, we have a video available showing how to remove a typical over the range grille and/or control panel assembly in under 5 minutes.
Accessing the oven cavity thermal cutout will require you to remove the oven from the wall, then remove the outer cover.
The installation instructions are included in your owner's manual.
If for some reason you don't have yours, you can download it from our site here.
Jun 19, 2011 | Sharp R-1406 Microwave Oven
There is still power but it will not turn on
It may be a bad fuse or a bad magnetron thermal cutout or oven cavity thermal cutout.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Accessing some parts (such as the thermal cutouts) will require you to pull the oven from the wall and remove the cover.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 11, 2009 | GE Microwave Ovens
Microwave will not power up and I know the power is good to the appliance
In addition to an internal fuse, most microwaves have a thermal cutout / thermal fuse or thermostat on or near the magnetron, and quite often on the top of the cavity, too.
Many brands also have a technical sheet inside the oven, either behind the control panel, hidden behind the grille, or inside the outer cover.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your symptoms, "dead".
Dec 06, 2009 | Microwave Ovens
How do i change the heating fuse for a ge spacemaker microwave
unplug first, take three screws out of top vent cover and there may even be some on the top cabinet holding vent cover on front, then you might see fuse holder just behind vent cover, if not remove screw(s) holding touch pad on, then slide touch panel up and out. it will rest on hinge, then you should see fuse holder inside behind touch panel. BE SURE TO UNPLUG FIRST AS ELECTRICITY CAL KILL YOU.
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a samsung smh7187 microwave over the range and in the middle of cooking it just shut off. The vent at the top of the unit is still open. The outlet is fine, other things work fine in it-I unpugged...
I would suspect the oven cavity's thermal cutout / thermostat, the magnetron's thermal cutout / thermostat, and/or the fuse.
Note that your model number's suffix may be different than this manual covers exactly.
Oct 04, 2009 | Samsung SMH7178STD Microwave Oven
No display, no light, no fan, microwave dead!
It may be the fuse, which is located in the upper area behind the control panel.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
(Don't be confused by the base or hood thermostat, which is on the floor of the chassis. It will read normally open).
The fuse and magnetron thermostat can be checked with out taking the oven down from the wall, but if you need to check the oven thermostat, you will need to pull it from the wall.
To help with that, you can download Whirlpool owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 25, 2008 | Whirlpool MH1140XMS Microwave Oven
Daewoomt1510W mocrowave over the range
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There may also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can visit Daewoo online or call them at 1-800-323-9668 or 1-800-553-4355 to find parts or find your nearest authorized service center to have them do the work.
Nov 22, 2008 | Amana MVH230 Microwave Oven
Fire help...need a new part or new microwave?
There is a flame sensor whose job it is to cut power if there is a fire. It has probably blown.
It may be called a thermostat, thermal cutout, or thermal fuse. It will look something like the drawings below. (The service info I have on this model is spotty).
But generally, there is one on the floor of the chassis behind the control panel. It should read open on a continuity test.
There will normally be two others, and they will read closed (also called shorted or zero ohms). One is on or near the magnetron and the other is along the top of the cooking cavity.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
NOTE: There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
May 16, 2008 | Amana MVH140 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
