Question about LG Washing Machines
LG dishwasher 4821st stops in mid cycle after replacing the control board. it ran one load then started stopping mid cycle after 2:58 minuets. New Display Control Board?
  • 76 Answers
SOURCE: Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
Posted on Nov 18, 2007
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
Posted on Dec 28, 2007
  • 7 Answers
SOURCE: Smelled like burnt board
reove screws holding on outer panel and unplug all the leads ( they are all coded so you cannot cross them ) open up plastic cover on module to reveal circuit boeard
Posted on Jan 07, 2008
  • 1073 Answers
have they checked the thernals on the bottom of the tub
Posted on Apr 12, 2008
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
My GSX4756 dishwasher seemed to stop mid cycle and the start light is flashing. I have pressed the start button until the light goes out but as soon as I close the door it starts again on the rinse cycle...
I think.
However, rarely have I encountered an inlet valve that emitted a burning smell. So I'd expect there to be some other problem in there.
But, if the inlet valve didn't pass the test, then it needs to be replaced. Plus, if it was stuck on the rinse cycle and the valve was out, then that is where the cycle would hang up.
Burning smells usually come from a motor, a belt, shorted wiring or a heating element. So if everything else checks out, then go for replacing the valve. The instructions are included in our dishwasher repair section.
Jun 27, 2008 | Bauknecht Dishwashers
Dishdrawer stops beeps mid cycle
It could have fogged up because you had the drawer cover off in the first place.
The problem may be the alignment of the mirrors. If the control board has slipped down so that the mirrors do not line up to the photo cell and led---that can cause the problem you are having. Make sure the mirrors (light tubes) are properly lined up with the photo cell and led on the control board. You may have to move the control board to make this alignment. Once aligned secure the board in place and this should solve your problem. NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU MAKE THIS REPAIR.
Aug 19, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
The water starts to come through then just stops and then alarms go off
see this causes and fix it. God bless you
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Oct 05, 2012 | LG WFT1071TP Top Load Washer
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Sep 05, 2011 | Dishwashers
DU1100 Stops mid cycle.
main control cpu unit failing
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
