Question about Kettler Exercise & Fitness
MY TREADMILL KETTLER PACER IS SMELLS FROM THE MOTOR AFTER 20 MINUTES AND THE SPEED GOES DOWN . WHAT IS THE REASON?
buffalonyman
  • 1865 Answers
SOURCE: Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Posted on Aug 29, 2009
maxtreadmill
  • 832 Answers
SOURCE: Noisy precor treadmill motor
that sound is due to the bearing failing inside the motor this is cause by capacitance discharge thru the armature thru the bearings. these unit can be rebulit I 've done plenty
Posted on May 14, 2010
SOURCE: I have a Proform 545s treadmill with incline and
i have a proform 545s as well and it would light up when pluged in but you could not use the speed settings at all. i figured out how to fix it just by tinkering around with it. i removed the back cover on the programer up top and exposed the circiut board. there is are 2 ribbon like sets of wires that come from the speed controler. the plug into the circuit board with a whit clip. pop loose the white clip on both of there and you will see a series of prongs that come in contact with the ribbon. using a small flat head screwdriver you must bend these prongs in slightly to close the gap between the two. it took me a couple tries to bend them enough to make contact again. i tried it and to my surprise it works great. the fan still is not working but i am trying to trouble shoot that now. hope this helps you....
Posted on Dec 15, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Nov 28, 2012
bireley
SOURCE: display shows LS1low speed code
I had all the low speed codes. Company sent new sensor and boards. I still had the same problem. My solution was found when I hopped on treadmill with motor cover off. I discovered the motor was turning properly but the belt drive was slipping. The belt was all oily so I cleaned the belt then tightened the motor tension with the adjustment screw. :)
Posted on Dec 09, 2013
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
Nov 25, 2014 | Kettler treadmill Pacer
Motor won't come on,everything works and motor is good
Check the voltages comes to the motor. http://electro-medical.blogspot.com/. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Jun 23, 2014 | Kettler treadmill Pacer
How can i oiling my kettler pacer belt ?
you dont oil it, you have to put treadmill wax on it, and you just put it under the belt on top of the deck at the front and the back
Apr 25, 2014 | Kettler treadmill Pacer
E1 error after start
this ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display. see the diagram attached.
God bless you
Nov 27, 2013 | Kettler treadmill Pacer
Ater starting the treadmill, it runs at 1mph then speeds up all on its own. The speed up button takes the speed down.Help please
Run the software calibration for easy diagnostic and fix it. Go under the HOOD cover motor and follow the steps.
God bless you
Sep 30, 2013 | Kettler treadmill Pacer
Treadmill KETTLER PACER - dc6 system fault, what I
Check if the drive motor is working
Power cycle...if still do not function calibrate or call 877-805-1030
Aug 10, 2013 | Kettler Exercise & Fitness
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
ERROR CODE # 7
2)Alternative:
My kettler pacer show e1
adjust the speed sensor see the diagram attached, clean it, and tight the connector very well.
2) test the input voltage motor, if there are the motor NEED repair
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Sep 09, 2012 | Avanti Exercise & Fitness
Exercise & Fitness Logo
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
