Question about Samsung Televison & Video
Samsung Plasma Tv with screen problems, not lines or bars, but spotty locations that are working.
I can see some menu come up in patches while most of the screen is dark. No reason to believe lcd has been damaged, as it just started having problem after working. probable board suggestions to test? Model PN50B550T2FXZA. I can upload example pictures of screen if there is a way to do so.
HDTV GURU
  • 261 Answers
SOURCE: Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Posted on Feb 06, 2008
  • 12 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Posted on Jul 07, 2009
tvservice306
  • 458 Answers
SOURCE: horizontal lines on tv
TRY REPLACED T-CON BOARD
Manufacturer Samsung Part Number BN81-01312A Description A/S-T CON BOARD
Posted on Dec 17, 2009
  • 111 Answers
SOURCE: Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Posted on Feb 04, 2010
  • 25 Answers
SOURCE: PLASMA TV PROBLEM
The problem with this set, is defective YSUS board, to avoid future same problem, you must change the following boards: YSUS, ZSUS & Control.
Verify with LG if your serial Number is included within
lots production that were recalled by this design defect
Posted on May 28, 2010
Testimonial: "I'll try to contact LG dealers. Very hank you sir"
Have a PN50C450B1DXZA Samsung Plasma TV and there are black lines going across the screen.The menu appears behind the black lines.Could the problem be the Upper Y Scan Drive or should I trash the TV?
It appears that the bondings on the plasma panel are giving way. The problem will increase with time and if I am not wrong, you will have to bear with it or change the tv.
Jan 18, 2018 | Samsung Televison & Video
Samsung 40"tv LCD HD got lines and black patches on screen model LA40A330J1XXA version ACO3 can it be fix Rasool
Look very like display panel fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 18, 2017 | Samsung Televison & Video
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Samsung 50inch plasma tv with colour patches over screen
A photo posted here or somewhere else with a URL (location) might allow me along with the Model number (not listed here) to help you.
To reply push the "make a comment button" on this page.
Mar 25, 2012 | Samsung 50 in. Plasma TV
My samsung PN42A450 42" plasma tv started showing
You have problem with the screen board this is located on the top and corner of your screen. The slight solution to do this is try resetting the connector on the main board and the screen board and the screen. it might works or not. Or re-soldered the part on the screen. If the symptoms look for service personnel to do it for you.
Sep 11, 2011 | Samsung PN42A450 Plasma TV
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
I have a white bar on the right side of the screen.
This is caused by either a bad address board (low $) or a bad plasma panel (high $). The only way to know is to replace the corresponding address board and see if it repairs the line. Hope this helps.
Mar 11, 2008 | Samsung HP-T4254 42 in. Plasma Television
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
