Question about Craftsman Garden
My transaxle on my riding mower has seized up and won't disengage with the freewheel lever. Craftsman 3000 is ten years old, has oil in case, no leaks; all has beeb fine till this year.
  • Craftsman Master
  • 2,478 Answers
Sounds like you need a new transaxle. You can remove it and unbolt it in half,check what wrong. Get parts from Crafsman store
Posted on May 11, 2017
Have a Poulan Pk 19h42lt transmission is not engaging linkage looks fine
If the drive belt is turning the input Shaft and the free wheel lever is not Dien gaged then the Trans is bad. Mine likes to slip the freewheel lever sometimes on its own. That is the lever you use to disengage the transaxle so you can push the mower. Transaxle are usually very expensive new.
Jul 30, 2016 | Poulan Garden
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Transmission won't engage
sounds like its time for a new mower
Apr 24, 2012 | John Deere Garden
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Brand new riding lawnmower, stop on hill, set park break, ready to go foward and when I push foward pedal and release break mower free whells backward. has 1 hr. on it. purged the trans. per instructions...
Sorry to hear about your aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Jul 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
What oil goes in the transmission?hydrostatic #944.608860
Hello, sorry to be the bearer of bad news, but the trans-axle on this is a sealed unit and oil cannot be added. The only thing you can do is an air purge or replace the trans-axle.
Doing a purge is really easy:
  1. put transmission in the freewheel mode so you can push it, ensuring that it is on a flat surface
  2. start engine and run full throttle
  3. release clutch brake
  4. push the drive pedal or lever to the full forward position for a ten count
  5. push the drive pedal or lever to the full reverse position for a ten count
  6. repeat steps 4 & 5 three times
  7. depress & lock the clutch brake
  8. return the transmission to the normal mode
  9. drive tractor
If this fails to correct the problem you may need to replace the transaxle.
If you find this helpful please vote yes. Thank You!!
May 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Jun 25, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman 15.5hp 42'' changed hydrostatic fluid with mobile 1 synthetic 15w50 and now the wheels will not rotate at all. Checked everything belts on right pulley turning on top of tranny, disengage for...
Purge the transaxle by pulling the freewheel lever at the back of the transaxle.With the lever in the freewheel position run the engine full speed with clutch out,work the forward/reverse control back and forth 10 times and then try it.Also make sure that if you had the wheels of that you didn't lose a wheel key.
Aug 15, 2009 | Craftsman Garden
Can't get stick to move down to disengage, push with all my power
With the engine off, reach under your deck and pull on the belt. This will force the idler arm back into disengaged position so you can start it. You can probably free the mechanism up with penatrating oil by spraying the pivot point on the idler arm ( the bracket the idler is mounted to that moves back and forth) while alternatly engaging the lever and pulling the belt till it frees up and returns by itself.
May 25, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
