Question about Home
How to unblock holding tanks
Do not know if they are actually blocked but little water comes out when I flush the tanks..Rockwood 2009 8315ss need to know how to tell
picatudo
  • 239 Answers
SOURCE: toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Posted on Jan 04, 2009
rahul26485
  • 611 Answers
SOURCE: my router blocked a website called facebook.com help
change the mtu value you get it
Posted on Mar 12, 2009
benni1023fm
  • 5 Answers
SOURCE: tiolet won't flush = water swirls but won't fully flush.
Mine does this too, from time to time. I've found that it usually means there's a plug somewhere down the line that you can't reach with a coathanger. Since I keep forgetting to buy a plunger, I use a johnny mop to vigorously poke in and out of the bottom hole until most of the water in the bowl is gone. After doing that, a couple flushes usually clears the line.
If that doesn't work, you'll probably need to use a snake on it.
Posted on Mar 17, 2009
Joy-1010
  • 11 Answers
SOURCE: blocked phone through imei nokia n95 8gb
You have to contact your service provider .
The IMEI (serial number) block on the phone, which stops it being used with a different SIM card, this may take up to 48hours to clear.
Please try to contact Customer Services of your provider. They will help to get you back and running.
More info about IMEI, please click here to check:http://www.1010store.com/forum/viewtopic.php?f=2&t=180
Posted on Jul 08, 2009
  • 5342 Answers
SOURCE: The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
Posted on Feb 19, 2010
To short of flush
Take the top off the tank and look at the water height. Adjust the float valve to raise the water to the line on the back of the tank. There is usually a little screw.
If the tank is already high, try holding the flush lever down. Newer tanks are dual flush, which a short flush with a quick press and release (for having a wee), and a long flush holding the handle down for ... well you get the picture :>)
Jun 30, 2015 | Plumbing
Not enough water goes into the Toilet Bowl, The Tank fills up fine but very little goes into the Tank, Terrible Flush
THERE ARE LOTS OF SMALL HOLES WHERE THE WATER COMES OUT OF IN THE RIM OF THE TOILET BOWL, SOME TIMES HARD WATER BLOCKES THES AND THEY NEED TO BE CLEANED. THEY CAN BE CLEANED USING A LARGE SEWING NEEDLE, PUSHING IT INTO THE HOLE UNTIL IT FEELS A BIT BIGGER, YOU WON'T DO DAMAGE AS IT IS VERY HARD METERIAL. a
AFTERWARDS TURN OFF THE WATER, AND LIFT THE VALVE AT THE BOTTOM OF THE TANK AND PUT SOME TOILET ACID INTO IT. THIS WILL ALSO HELP CLEAN THE HOLES.
May 22, 2012 | Kohler Toilet - One Piece with Ingenium...
When flushed, not enough water coming from bowl rim holes to wash waste off sides of bowl. Have checked holes around top rim, none are plugged. This has been a problem since purchased one year ago.
Its simple. Check to see if you installed toliet right by removing top of tank and holding handle all the way down. Did it flush from all rim holes? If not, then u will need to get a garden hose with a sprayer to increase pressure and shot high volocity water at rim holes to unblock it. Remember the very front on newer blows do not have holes its a pee shield. Also try doing these other things adjust screw inside tank to make sure the bowl has enough water in it to do a good job. Check the rubber tube going into the hollow pipe and make sure it is going fully inside the plastic pipe that is sticking out of the top of the water in the tank. Also you need to have enough water in tank to allow it to flush good. To increase tank water levels then just unscrew the big plastic ball (or just bend wire to allow more water or bend to allow less water) at top of water in tank. Also increase (max) water pressure at wall to allow it to work at its best. If you have hard water it can cause problems but you say it happened even new, so, you do not have to go in that direction.
Oct 06, 2010 | Kohler K-3497 Cimarron Comfort Height...
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
I have to flush three time just to get one piece of toilet paper down
the first thing to look at is to see how much water is in the system if its very low it will only give you a short flush take off the top and see how much water it is holding when full up, if its lower that the over flow pipe you could rase it a little by lifting the ball to let more water in, then have a look at the bole itself were the water comes out there are a row of holes if there blocked with lime scale you will need to clean them all out its a messy job i know but this scale will slow down the flow of water and there wont be the forse to clear the bole out, an old drill bit of the right size will easly clean the holes out, dont just try useing lime scale remover and a stiff brush as it wont get right into the holes they need to be clear right through to the water pipe from the header tank ie: about 1.5 inches so only doing the job by hand will do this
it should work ok after that
best of luck,,,with a nasty job
Dec 01, 2009 | Optics
In the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again? (its an eljer 2001)
is the black thing between the the tank and the bowl?
if so, go to any of the home center or plumping store for the seal.
shunt off the water and unbolt the 3 bolts that holds the tank to the bowl from the buttom. you may need a flat screw driver to help hold the bolts. pull up the tank slowly, and lay it on the side, replace the seal, reseat the tank on to the bowl and tighten the bolts. make sure all bolts are equal pressure and the tank is level.
May 05, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Water comes from bottom of tank when commode is flushed. I have a two piece toilet, upon flushing it water pours from in between the two joined parts-tank and commode.
You need a new tank gasket. It is a rubber piece that seals between the tank and the bowl. They are fairly inexpensive and if you have patience and a little plumbing know-how; they can be changed at home. Here is a good on-line set of instructions:
http://wiki.answers.com/Q/How_do_you_change_the_gasket_between_the_toilet_tank_and_the_toilet_bowl
Mar 27, 2009 | American Standard Colony 2388.012.222...
Delay on tank fill after flush. Toto Drake bowl ada elongatred
I am not a plumber but stumbled across the solution on my own. While watching the float during the flush cycle, it was obvious that it was very slow in moving downward along with the water level in the tank. The problem was that the small opening in the float chamber was partially clogged. Using just my fingers, I reached under the float chamber and cleaned off any debris that was blocking the opening underneath the float chamber. Put the float back on, and instantly the problem was solved. The tank fill started immediately after I flushed.
Mar 09, 2009 | Toto Drake ADA Compliant Toilet with...
1989 jeep laredo overheating
Have the cooling system flushed and radiator roded out.
Dec 14, 2008 | 1989 Jeep Cherokee
Home Logo
42 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
