Question about Murray Garden
How to change head of Murray 2500 weedtrimmer
Removing stripped screw off murray 2500 weed eater
If the screw still has some definition in it, putting a rubber band or a piece of duct tape over the screw driver can add the needed grip to remove most screws.
Jul 14, 2017 | Murray Garden
How long is the life span of a murray 2500 weed eater
That is nearly impossible to predict because I don't know how well it is maintained and or how often it is used
Jun 30, 2017 | Murray Garden
How to remove a murray trimmer head
Hi Christina,here's a video showing you how to remove head and restring. How to String Murray 2500 Edge Trimmer Wead Eater Walmart wind up
Aug 27, 2016 | Murray Garden
How do i change a coil wire on a murray 2510 weed eater?
Murray Trimmer Product Support ' ManualsOnline.com
www.manualsonline.com/support/murray/trimmer/
Does Murray Weed Eater MS2550 use straight gas or. Murray ... HOW CAN I DOWNLOAD MURRAY 2510 TRIMMER MANUAL??? Murray Trimmer M2510.
Mar 13, 2015 | Garden
Starter gear strips after a couple times of starting on a 20hp briggs&stratton engine on a Murray lawnmower
bad compression release valve do a valve job and put in new valves or crank bearings bad do short block better just by new engine save the head ach with the motor valve job 100.00 per cylinder short block 300.00 or 400.00 plus 150.00 to put to gether best buy new tractor
Sep 11, 2014 | Murray Garden
Is there a blade attachment for the murray m2500 weedeater?
I believe you are incorrect in assuming the murray 2500 is a cable drive. I had the end of mine apart today and there was two bevel gears for the bend connecyed to a shaft, not a twisted cable. It also is described as a straight shaft trimmer. Please do your homework before answering someone.
You are correct that you cant add an attachment though. It doesnt have an arbor to attach the blade to like most do.
Jul 01, 2014 | Garden
Torque specs...
The standard specs for grade 5 head bolts are:
5/16" bolt with 1/2" head is 26nm or 19 ft lbs.
3/8" bolt with 9/19 head is 45nm or 33 ft lbs.
junkl
Aug 23, 2013 | Murray Garden
How do you change a head gasket on a 16.5 hp briggs & stratton engine
Go to you tube and on the line type change head gasket on
16hp b&s.
Jul 13, 2012 | Garden
What needs to be done to remove the head off of a stihl weedeater?
If you are talking about the spool and string area, remember that Stihl have left hand threads so you turn it the opposite of lefty, loosy, righty tighty. There is a small hole in the side of the head to insert a special tool that came with the weedtrimmer when you purchased it. If the tool isn't available use a small phillips or flathead screw driver to hold the gear box still while unscrewing the head counterclockwise.
Jun 14, 2009 | Garden
Garden Logo
94 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
