Question about Health & Beauty
How to repair a HEM-711 from no air to arm cuff for blood pressure reading.
  • 10 Answers
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. 30ad4e8.jpg
Posted on Oct 13, 2009
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
  • 4736 Answers
SOURCE: I have an Omron Model
After 5 years, the unit probably needs re-calibrating. In which case, you'll need to have the manufacturer do that. Most off that service free of charge or just a minimal charge. Contact Omron.
Posted on Mar 26, 2011
  • 4736 Answers
SOURCE: Neither of the cuffs
Robert, I'm not sure that the cuffs would be interchangeable. But, I suspect the problem you're having with the cuff is operator error. Speaking from experience, it's somewhat difficult at best, to apply and arm cuff to yourself. It does take some practice, but if you can get the cuff snugly in place, it should inflate properly. If you want to pursue with interchanging the cuff, contact HoMedics at 800-469-3342, to see if it's possible. Perhaps, you should get a BP Monitor that has a wrist cuff. They're a lot easier to apply and use.
Posted on Apr 01, 2011
  • 23 Answers
SOURCE: how to reset memory on
Posted on Oct 18, 2011
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
Only memory works on y HEM-711 start stop button does not work . Is it worn out?
Time for a new machine. That could be the controller or the switch board that is bad. You cannot get parts.
Oct 06, 2016 | Omron HEM-711 IntelliSense Automatic Blood...
I am using OMRON Automatic blood pressure monitor Model No HEM-711 Now it is not working. Where can i get it repaired. I am staying in Calicut Kerala
Not sure it would be economically repairable, but you can reach Omron customer support here:
Nov 01, 2014 | Omron Automatic Blood Pressure Monitor w/...
Can you calibrate omron hem-711
I check the accuracy of my Omron every year. It is important that your device must give proper results.
Jun 04, 2012 | Omron Automatic Blood Pressure Monitor w/...
I have an Omron Model HEM-711 AC which is about 5 years old. When I use it the reading sometimes it will vary about 10 points if I take my blood pressure several times in the same sitting. Sometimes...
Mar 26, 2011 | Health & Beauty
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
My Omron 711 seems to register readings that are too high when compared to doctor's office or monitors in drug stores, etc. Is there a way to check accuracy of the monitor?
Take the cuff to your doctors office and have the nurse check with yours and the office BP cuff. If your cuff is too small, you will get a false high reading.
Nov 30, 2010 | Omron HEM-711 IntelliSense Automatic Blood...
Model HEM 780N2 register E after reaching 15 - replaced batteries, what now?
After using the Oregon Scientific pedometer with pulse meter (disaster ..... I couldn't find a PC ready model separate from the software so now I own to ..... Update 2: I just replaced the battery (CR2032) so I guess it lasts about .... Replacement Cuff for HEM-780N, HEN-780N1, HEM-780N2, HEM-780N3, and HEM-790IT ...
Dec 04, 2009 | Omron Auto Bp Monitor with Easy Wrap Cuff...
How to read the machine omron hem 711
There are 3 major things, Systolic/Diastolic and Pulse. You want the numbers to be 120/80/varies...... anything outside this is considered an alert and should be brought to your Dr's attention
Jul 30, 2009 | Omron Healthcare 2007 Hem 711DLX Automatic...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
