The flashing lights stopped after i did the turn off and then turn on outside at the unit. The operation light is on only now but it appears only cool air coming out i have reset it to 26
bobotfel
  • 236 Answers
SOURCE: green light flashes 3 times will not operate
Its may be the thermistor is defective or out of range or the board itself, the unit will not operate unless the defective part is not replace.
Posted on Mar 09, 2008
SOURCE: Reset light comes on, unit stops operating when tank is full
I was up all night with this since I just purchased it yesterday and I wanted to be certain that there wasn't some simple alternative to returning the humidifier since the reset light keeps going on immediately after I turn the unit on AND I've already followed all the directions to the T. Believe me - I was ready to return it cause ain't no 38.99 worth me doing all this tinkering and trying to figure out why they couldn't make the unit correctly cause apparently A-LOT of people have this problem. If it wasn't for my three children being so ill including myself getting sicker going out to purchase the humidifier and I was trying to avoid going back out to further compound my illness----I WOULD have just returned it. MAYBE I still will return it. ANYWAY, here's the deal: the water in the tank SHOULD flow into the boiling chamber where of course steam rises from there; however, the WATER VALVE in the CAP to the water tank does not allow any water to flow into the boiling chamber because it is so tight. The reset light goes on as if there was no water in the tank because of course, the heater is on, but no water is getting boiled because the water can't get in. There are a few things you can do. First: the water valve is a little stick and a spring within a piece of rubber that can be slipped out of the cap (this is what I chose to do). Now the water flows easily and even with the unit set to high, there is no problem. It just works. Second: You could remove ONLY the stick and spring from the water valve's rubber piece. This would work if the hole in the rubber piece happens to allow steady water flow (mine wouldn't). Third: you could probably do some cutting til you were satisfied with the results.
Posted on Feb 01, 2009
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
dhj144
  • 80 Answers
SOURCE: My Air conditioner stopped putting out cool air.
The unit is overheating and tripping the internal overload of the compressor. Clean outdoor coils.....check outdoor fan to see if it turns or is siezed......possible bad Start/Run Capacitor which is a very common failure on condensing units......possible bad fan motor need replaced! Unit compressor can be cooled with a water hose to get it to reset the internal biometalic high limit switch that is located in the hermetically sealed compressor!
Posted on Aug 22, 2010
hvac1960
  • 2133 Answers
SOURCE: air con not working. Operation
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Posted on Dec 31, 2010
Lennox ac stops working after normal shutoff untill i shut off power to air handler turn power back on ac runs till nornal temp reached shuts off will not come back on untill i kill power to air handler...
The 13HPX is a Heat Pump. It has a control board in the outside unit that will lock out after a few trips from one of the controls, such as a low or high pressure switch tripping. Turning the power off is making this board reset. Take the door off next time. to the outside unit and look at the lights on the control board. There should a sticker on the inside the door that you have to remove that describes why the unit is hard locking out according to the light configuration.
Oct 24, 2017 | Heating & Cooling
Light not working
Your light may be in lock mode, press the power button for several seconds and the button should turn or flash blue. Normal operation should be available. If this doesn't work, you may have a defective unit and will have to return it to NiteRider for warranty.
Apr 14, 2014 | NiteRider Lumina 350 Bike Light
I have a kelvinator ksr25f split system.The green light on the front panel flashes when the unit is turned on.The unit cools ok and when the temp is cool enough the outside unit stops as normal but doesnt...
Check and make sure the outside fan is running. The KSR series Kelvinators were rebadged LG units. It is possible the 6uf fan capacitor on the outside unit has failed.
Mar 04, 2014 | Heating & Cooling
Fujitsu heat pump flashing code?
Test the fuses for the outside unit.
Aug 29, 2017 | Heating & Cooling
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
I have Fujitsu air conditioner Model abt45rba3w Serial t000147 The unit will not operate. The red operation light is flashing fast continuously and the a/c unit will not turn on. The timer light is...
Have you checked for compressor operation? If it is not running you may need to replace the hard start relay/capacitor. If you remove it and get the numbers it is available on ebay for a fair price. eBayeBay
Sep 07, 2017 | Fujitsu Heating & Cooling
Minolta Maxxum 3200i Flash does work
Try to short out the flash and see if the flash flashes.
Remove flash from camera.
New or fresh bateries installed.
Get wire with insulation and remove both end bare to 1/4"
Turn on flash and wait until light turn green or ready.
Touch one lead to center of flash pin, touch other end to the outside(rail on the side) pin.
Flash should discharges.
atdlee@netzero.com
Jul 28, 2008 | Cameras
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Ac runs for a while then stops and operation light flashes
Hello, It depends what refrigerant the system is on but if it tripping out on HP it could be overcharged with gas or a problem with the outside condesor fan.
Feb 02, 2007 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
