Question about Casio Office Equipment & Supplies
Casio sl 300sv
How do I change the decimal point to 2?
SOURCE: Display a decimal point
Turn the calculator off, then press and hold down the .(decimal key) while you press the on button. Doing so again sets the calculator to use the original digit separators in the display
Posted on Jun 27, 2007
  • 91 Answers
SOURCE: I lost my decimal point
You need to be in add mode, and have 2 decimal places selected for the result.
To change to add mode, make sure the 'K . A' switch is in the 'A' position. To get 2 decimal places in the answer, move the selector in the 'F 6 3 2 1 0' switch to the '2' position.
You can see the above described at
this page which shows the users manual. The manual shows examples.
Posted on Mar 19, 2008
SOURCE: HP 12C calculator
turn the calc off then turn on holding down the decimal.
Posted on May 08, 2008
  • 3 Answers
SOURCE: setting it to 2 decimal points
You have to make sure that the third set of buttons wit the K*A is set to A and the 5th set of buttons is on the 2.
Posted on Dec 16, 2008
SOURCE: how to change comma into decimal point
Turn the calculator off, then press and hold down the . key while you press on.
Doing so, sets the calculator to the original digit separators in display.
Posted on Jan 22, 2009
I know the S<->D button that it will change from fraction to decimal, but my calculator happens to change from fraction into scientific notation! i did what the others said to Press SHIFT MODE 2 to...
You want to change the display mode. Press SHIFT MODE. Then press 6 and a number specifying the number of digits after the decimal point for fixed decimal notation, or 6 and 1 or 2 to specify one of the floating point modes.
Sep 18, 2011 | Casio FX-115ES Scientific Calculator
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
My answers always come in fractions by default. how do i change the settings so they come in decimal points by default? further. how do i change the settings to have the answer in decimal points up to 4...
Press SHIFT MODE 2 to select the LineIO mode. To select the number of displayed digits in fixed decimal notation, press SHIFT MODE 6 and select the desired number of digits.
Oct 21, 2010 | Casio fx-300ES Calculator
The calculator doesn't show decimal points. How do I change that?
To convert a single value between decimal and fractional notation, press the SD button. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Aug 31, 2010 | Casio FX-115ES Scientific Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
How do I get my Casio calculator to show only 2 numbers after the decimal point?
Use the FIX format with two decimal digits
[MODE][1:Fix] 2 displays only two decimal digits.
Hope it helps.
Sep 03, 2009 | Casio FX-300MS Calculator
Rounding off in Casio FC 200V
Press [SETUP] select FIX then press [EXE]. Enter the number of decimal digits you want (3 or 4). Press [ESC] then press [EXE]
Hope it helps.
Dec 14, 2008 | Casio FC-200V Scientific Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
press subtotal to finalise the tax table you are on
Hope this helps,
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
