Question about Power Computers & Internet
I have a Seiki TV SE47FY19 and I had to replace the main board but I forgot how to plug in the inverter cable with the power supply.
I have a cable that has 4 pins (with 3 cables in it) and the power supply board as 6 pins...where should I connect it to? the pins on the power supply read as follows GND GND ADJ L/ON +12V +12V
  • 13 Answers
SOURCE: RCA d52W19Byx1
Check to standby voltages, the three of the five and a 7.5 voltage going to the SSB main PCB if these voltages are there most likely have no horizontal drive.  You'll need to replaced the SSB part # 264120. I recommend that you have an authorized RCA servicer replaced the board, convergence data needs to be uploaded to a computer via a chipper checker.  Because a full convergence is quite difficult.
                                      Packman
Posted on Oct 29, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Firewire on Inspiron - Connecting Canon MD 120 camcorder
Browsing over the md120 specs, included should be a software disc for the usb connector, so it shouldn't matter whether you use an adapter or the 4 to 4 cable. This disc will have the drivers and software for using the camera in conjunction with your laptop. Have you tried this download for the camera.
http://software.canon-europe.com/products/0010449.asp
Also check out this link. Towards the bottom under additional features it lists software, drivers and utilities, and at the bottom under supplied accessories it lists application software/usb driver. Go to the store you purchased this at or contact Cannon support and get the disc that was supposed to be included.
http://www.einfo.co.nz/shop/product_info.php?pName=sony-dcrdvd908e-20x-optical-zoom-camcorder
Posted on Jul 30, 2008
SOURCE: 19" Proview 900p lcd monitor backlight
The 7812 device is a voltage regulator. Either the reg has failed or the input to the reg is no longer approx 12volts. It should be more than 12volts so that the reg can control the o/p .
Posted on Sep 05, 2008
  • 64 Answers
SOURCE: AKAI Flat Panel TV...AC connection at the power supply. HELP!
It's the solo one, next to the ground screw.
Posted on Sep 09, 2009
  • 700 Answers
SOURCE: I need canon gp 405 Service manual that contain
this site have service manual which contain most of requested bits, including how to and what to do. it is not for faintharted do... :-)
http://www.scribd.com/doc/16699855/Canon-GP405-service-handy
if you find my answer helpful, please rate it, thanx!
Posted on Jul 31, 2010
My Seiki Tv has no sound but a perfect picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 09, 2017 | Seiki Televison & Video
My Seiki Tv keeps flashing the program we're watching
Jan 22, 2017 | Seiki Televison & Video
My Seiki Tv keeps blinking on and off
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Hello, I have 40 inch seiki tv I have a problem that the tv power work on I hear sound but the screen is blank can't even see it. What should I do or what should I buy part to fix it?
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 12, 2016 | Seiki Televison & Video
I have a seiki se501ts tv. Good sound, bl a n screen. Whatboard do i need to replace? Thanks!
Jun 26, 2016 | Seiki Televison & Video
Where is the LED driver on a Seiki SE47FY19 47 in. flatscreen?
Feb 10, 2016 | Seiki Televison & Video
Seiki tv repair
Nov 22, 2015 | SEIKI Digital SE47FY19 47" LED TV...
Does not have a picture
Oct 01, 2015 | SEIKI Digital SE47FY19 47" LED TV...
My 32in seiki tv model number SE322FS has black screen no picture just sound
Aug 28, 2015 | Seiki Televison & Video
How do I repair my Seiki tv?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 22, 2014 | SEIKI Digital SE47FY19 47" LED TV...
Computers & Internet Logo
32 people viewed this question
Top Power Computers & Internet Experts
john smith
Sattech
Level 1 Expert
MonsterByte
Level 1 Expert
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
