Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Need help I set the valves on my 13.5 Briggs and now it won't stay running unless I close off the airflow to the carburetor
SOURCE: Need carburetor adjustment
I had a similar problem with my 23 hp briggs. While cleaning the carb I found that the great gas we get today had eaten the seal around one of the jets in the throttle body causing it to fall out. Replaced the jet and now runs like a champ. Hope this helps.
Posted on Jun 07, 2009
  • 225 Answers
SOURCE: carburetor adjustment
have you checked the air filter,if that is clean I think I would replace the carb, diaphram.
Posted on Jun 21, 2009
  • 691 Answers
SOURCE: Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Posted on Sep 01, 2009
Testimonial: "This guy really knows what he is talking about. I would highly recommend him."
bulldogchief
  • 388 Answers
SOURCE: I have a Ryobi string trimmer that will start
Have you ordered a gasket kit for it? If you have already rebuilt the carburetor and still having this problem most likely means you have a vacuum leak somewhere. Take the carburetor off and look at the intake manifold, there is a gasket on both sides. A gasket kit will allow you to replace both of those gaskets which should fix your problem...hope this helps.
Posted on Sep 15, 2009
backwoodsctr
  • 169 Answers
SOURCE: 11 hp briggs and stratton engine blows gas back
u have a poss bad intake valve and or a poss sheared flywheel key causing the engine to fire when the valve is open Hope this helps!
Posted on Nov 19, 2009
Hard stating flooding
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    https://www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    It won't start. ... Rider mower carburetor flooding - help ! .... ( HOW TO ADJUST VALVES) FIX HARD TO START Lawn Tractorwith OHV Briggs ...
    How to stop a Briggs crankcase from flooding with gas Order ...
    ? 11:34
    https://www.youtube.com/watch?v=VhEiLMtPR5M
    Aug 5, 2013 - Uploaded by doublewide6
    If your tractor keeps leaking gas into the crankcase see how you can fix the problem by ... The hard starting is caused by fuel filling the cylinder.
    Basic Troubleshooting - Lawn & Garden Tractors - Cub Cadet
    cubcadet.custhelp.com/.../basic-troubleshooting---lawn-%26-garden-tract...
    Sep 13, 2002 - Engine fails to start, Engine flooded, Crank engine with throttle in FAST... Engine runs erratic or stalls, Tractor running with CHOKE activated ...
Jan 25, 2016 | Garden
Why won't my 1986 Honda Magna VF700 stay running when I give it gas
Hi, Aaron and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1984 VF700 Magna starts but won take throttle
Help flummoxed Hard starting VF700
https://drive.google.com/file/d/0B6uU39dq308cNTUzODE4NmYtMDIxNy00MzAwLWFkZDUtNDNkMWUxYTVmYWQx/view?hl=en
http://www.partsfish.com/page/oem-parts-for-honda
Honda VFR750 RC24 Owners Manual pdf
Jun 11, 2014 | Honda Motorcycles
Ignition on 02 fatboy fuel inj
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Sep 23, 2013 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
Spark keeps fouling out
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Won stay running
Royal Star Venture and Tour Deluxe Forum
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
http://www.yamahaventure.nl/pdf/ownersmanualxvz13tf.pdf
Sep 05, 2012 | 2007 Yamaha Royal Star Venture
Will start and run .wont take throttle . clean carb good fuel flow
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intake air leak.
8. Water, dirt, or rust in the fuel system, carburetor and/or filter.
12. Loose, dirty, or corroded ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and/or CMP sensors.
16. Damaged intake or exhaust valve.
For more information about your issue and free downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
http://www.buellxb.com/forum/showthread.php?31223-Blast-has-trouble-starting-and-won-t-stay-running-unless-you-throttle-it
http://www.badweatherbikers.com/buell/messages/20164/150578.html?1444533833
Buell Service Manuals PDF Download
TWIN Motorcycles Buell parts
2001 Buell Blast Owners Operators Owner Manual Factory 2001 eBay
Feb 16, 2012 | 2005 Buell Blast
I have a lawn vacuum which uses a B&S 129882-1936-d1 engine. I can start it on one pull, but then it quickly dies. I've checked and have airtight seal. WHat I can see is that the throttle cable...
I'm surprised you can't move the linkage yourself. The spring is attached to an arm that goes back under the cowling. That are has a blade on it the sits in the airflow of the motors cooling fan. As the motor runs faster the blade causes more tension on the spring and changes closes or opens the carburetor a little. The throttle cable and the fan set the position of the carburetor. Check to make sure the the blade up in the airpath has not somehow gotten jammed. Also the choke setting can cause the problem you describe. Make sure it's linkage is not binding somehow...
Sep 22, 2010 | Briggs & Stratton Garden
VALVE ADJUSTMENT ON 13.5 HP BRIGGS AND STRATTON ENGINE
Sep 20, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Have a Briggs & Stratton 4.5 hp 158cc engine that will not stay running. I have changed the primer bulb, diaphragm, filter and intake o-ring. It will still not run unless I keep priming it with fuel.
Check to see if there is a small hose coming from the valve cover to the carburetor body--this is a fuel pumping pulse from the crankcase. Hope this helps!
Aug 14, 2010 | Garden
2004 Honda CRF 150 F won't stay running
Hi, Smiley1961 and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
more help with the 150r please won stay running
Brand new CRF150 won stay running
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2004 CRF150F Owner Manual
May 09, 2010 | 2004 Honda CRF 150 F
I have to close the choke for it to stay running it run rough
your cutting the air flow off to the carburetor allowing more fuel in, check all fuel lines, and filters, and fuel pump if you have one. If all ok than your going, to need to flush the int-ir fuel sys (clean). replace your fuel filter, and over haul the carburetor. replace your plug and oil too. Use a good aerosol carburetor cleaner. After your done use fresh fuel (stabulized). adjustment may be needed to the carburetor. Some Carburetors Are EPA and no adjustments are needed except idle screw. good luck I hope this helped.
Oct 17, 2009 | Briggs & Stratton Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
90 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
