Question about Brother Office Equipment & Supplies
Why my brother machine stops and then starts after a few minutes.
My Brother PC 8200 was doing an embroidery pattern and suddenly sped up and went crazy! I can't get it to stop sewing motion except to turn all power off. Stop/Start button is red but non-responsive
*Grin* I use to have this machine! It's a very old machine and may not be worth repairing. *tear* It sounds like the on/off switch is broken and un-responsive. The "Sped up and went crazy", part sounds Motherboard related. You never know; take it to a Authorized Brother repair shop motherboard....
Happy New Year!
Kelly
Embroidery Services
San Diego, CA
Jan 01, 2015 | Brother Sewing Machines
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
How to Stop Printing while it is Printing ?
Start by pulling the paper tray out. This will cause the printer to finish the page it was on when it was interrupted rather than paper jam somewhere in the machine.
Once you have interrupted the print job this way then you can cancel the print job from the PC and then once that has been done turn the Printer off for a few minutes to clear the memory buffer.
Turn it back on and it should be cleared.
Mar 13, 2014 | Brother HL-2135W Mono Laser Printer Page...
My machine is LG intello washer 7.5kg WD-1025FB the machine can start work, but after few minutes, it stopped and only can hear motor making noise. i turn of the switch start again, same as before: work...
Sounds like you may need new timer. They have contacts in side that control all fuctions of you machine if those contacts start failing or get burnt the machine will hit a certain spot in the timing and then it will stop or stall.
May 04, 2011 | LG Washing Machines
Clear memory of Brother intellifax 2900
with this model, power the Brother fax machine off with the power button, then, while holding down the Stop button, power the fax machine back on. Keep the stop button held down for a few seconds. That should clear the jobs resident in memory.
Aug 19, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Won't print after warms up
Check the status of your fuser unit. If it is ok then the problem comming from main board.
Nov 16, 2008 | Brother HL 5250DN Laser Printer
Brother MFC-420CN
press menu then start b/k copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press start b/k copy: What two digit error code does the machine display? Post here again.
To leave the maintenance mode press 9 then 9.
Mar 07, 2008 | Brother MFC 420CN All-In-One InkJet...
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
