Question about RCA Lands Phones
I can register the other 2 rca telefield 6.0 handsets
I already registered one to page 1 but the other two I can register to page 2 and page 3
  • 3 Answers
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
Posted on Feb 14, 2008
SOURCE: Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Posted on Oct 03, 2008
SOURCE: How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Posted on Mar 12, 2009
SOURCE: How to remove Uniden handset from base
The brillian people at Uniden don't feel it necessary to provide this type information in their manuals. You have to trial and error to find it, but what can you do. All you have to do to reset the base unit itself is to unplug the power, then while holding down the delete key, plug it back in. Hold the delete button down until you hear a beep, which indicates it has reset. Now you can readd handsets and they will start at 1.
Posted on Jun 27, 2009
  • 7993 Answers
SOURCE: handsets do not register
Press the END button to exit or erase the message. Press Menu/Select. Scroll uo or down to find Register Base. Select the option, select it and put the handset in the charging cradle of the base. A confirmation beep will sound.
Posted on Jan 12, 2010
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
In that case, you can clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
1. press [menu]
press [select]
(this is why the cover was off)
replace the cover
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
blink. 2. release the [Find Handset] button momentarily,
ready for fresh registration ===============================
( III.) To register each handset to the base:
"Handset #x" or it will say "Registration Failed".
few hours and try the registration ( III ) again.
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
Vtech cordless handset CS6209 will not connect with CS6229-2 base
Yes. The'old' handset must be de-registered from its
NOTE: the CS6229 handles a maximum of 5
You will need to clear each handset ( I ) then clear
1. press [menu]
press [select]
replace the cover
Good luck !! --
Jun 08, 2013 | Vtech Lands Phones
How to reset vtech i5858
Follow the instructions on page 38 of the manual.
Mar 07, 2012 | Vtech i5858 Cordless Phone
I need to deregister missing handset #1
To de-register HANDSET #1:
1) Grab any working handset which is registered to your base (so HANDSET #2 or #3 in your case)
2) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
3) Choose the "Deregister HS" menu option
4) Pick HANDSET #1 as the handset ot de-register (since that's the "phantom" registered handset)
5) Once de-registered, you can de-register handsets #2 and #3 directly from each handset's "normal" menu interface (i.e. press "Menu", choose "Deregistration")
6) Thereafter, if you re-register your handset, they should start at HANDSET #1, then #2, and so on.
Aug 27, 2009 | Uniden TRU8866 Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Dec 10, 2008 | Motorola Mobility MD41 Expandable Handset...
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Lands Phones Logo
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
