Question about Dyson Vacuums
I have a Dyson Ball Allergy Upright Vacuum. When using the wand and hose, the hose portion becomes tight and hard to work with. There are no blockages.
  • 55 Answers
SOURCE: Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Posted on Dec 02, 2008
  • 83 Answers
SOURCE: I have Dyson animla and the wand stop working....no bloc anywhere
The hose is getting twisted on the machine and that makes it difficult to pull it out.
1) Pull the wand out as far as you can - if you can pull it out completely, separate it from the hose and apply baby powder to the metal rod. Stretch out the hose and unwind it. In the future, separate the wand and unwind/stretch the hose after use.
2) If you can't pull the wand out all the way, remove the u-bend from the bottom of the machine - turn that plastic screw at the bottom next to the gray hose 45 degrees anti-clockwise and take the u-bend off.
3) Pull the hose out from the bottom (don't pull it out all the way - just enough to release the wand) and pull the wand at the same time - separate the wand from the hose and unwind the gray hose and stretch it out. Rub baby powder on the metal rod of the wand and in future, disconnect the wand from the hose and stretch/unwind the hose after every time you use the wand.
Posted on Jul 30, 2009
pippall
  • 1486 Answers
SOURCE: Blockage in pipe of my dyson slim dc18
There sould be a rubber flap under the pipe.Pull it down to remove dust and **** that gets stuck.
Posted on Dec 27, 2009
Testimonial: "He was very helpful in his suggestions and after the first suggestion didn't work out he provided another. Thanks for the help."
SOURCE: Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Posted on Apr 18, 2010
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
I have no suction when I use my tools.
I haven't much experience of Dyson cleaners but I believe if there is no suction at the end of the wand when it is being used with tools there will be the same absence of suction when the wand is in place for use as an upright.
If that is so perhaps it is time to service the filters. I suggest you refer to the instruction manual.
It is possible the hose is blocked and needs rodding out.
Feb 25, 2015 | Dyson DC18 all floors Bagless Upright...
How to get suction to wand
Pull up the wand fully and you should hear a click. If not, make sure that the hose is not kinked. See this video: http://www.dyson.co.uk/support/dc25/dc25-irsvsye/my-machine-is-not-working/jammed-wand-video to find out how to unkink the hose. hope this helps.
Aug 14, 2014 | Dyson DC25 Multi Floor Upright Ball...
The brushes do not disengage when in upright position
Set the brush control, as needed. The brush control turns the brushbar on the underside of the vacuum on and off. The button is located beside the power button, on the top-front of the vacuum cleaner. Turn on the brush control for cleaning carpet. Turn off the brush control for bare floors or delicatelb_icon1.png rugs..
Feb 25, 2013 | Dyson DC15 All Floors - The Ball Bagless...
Why does my dyson vacuum cleaner tip over when using the wand
Your Dyson should not tip over while you're using the hose and wand. If it seems to be doing this, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), as we may be able to offer some helpful advice on the best way to use the machine.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Jan 11, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC07 Vacuum Cleaner
It sounds like to me that you probably have a clog in the hose port, or that your attachment hose may have a hole in it. Both of these problems are common problems on the Dyson DC07 model.
The first place you should check is the clog part that's directly underneath of the hose. Pull this port out and see if you can see anything lodged inside the clog port:
If you aren't able to find the clog here, then pull the wand and hose out of the vacuum. With the vacuum cleaner off, pull the hose out as far as it goes, and inspect the entire hose assembly from the end that the wand connects into, until the end that fits into the vacuum itself. A lot of times this hose will tear due to the sharp end of the wand as the hose is being pushed back up the wand.
If neither of these solutions worked, please just use the clarification request form here on the Fixya repair page, and I'd be happy to do some more advanced diagnosing with you to figure this out.
If this was helpful to you, please help other Fixya users find this answer by rating the repair helpful, by clicking the thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 11, 2010 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Kind regards
Darran
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson exrenable tube wont lock in
Hi there, its Darran at Dyson.
Sorry to hear of the problem that you are experiencing with your Dyson vacuum cleaner.
If you are having trouble locating the wand handle back inside the hose, it could be that the hose itself is blocked. Remove the wand handle completely from the hose, then un-clip the hose from the base of the machine to check for blockages.
To ensure you are correctly stowing the wand handle, please check your user guide or our website at www.dyson.com and visit the Support section.
Kind regards
Darran
Dyson Customer Service
Dec 24, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Hose attachment
Your wand is getting stuck in the hose because the hose is twisted - you need to unwind it:
1) Pull the wand up as far as you can, all the way if possible
2) Stretch the hose out and unwind it, use some babypowder on the metal part of the wand and in the future, unwind and stretch the hose out after you use it
3) If you can't get the wand all the way out, remove the canister from the front, push the button where you see the 7 vertical grooves (on the opposite side of the hook that you wind the cable around) - then pull on the hook and pull the hose up and off of the machine - stretch the hose out from the bottom and pull the wand out - now apply baby powder to the metal rod and disconnect and stretch and unwind the hose every time after you used the wand to clean.
Jun 25, 2009 | Dyson DC25 All Floors Bagless Upright...
Nov 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Toy stuck in hose
Generally, this is a job for patience!  First, remove the hose from the unit.  Try a broom handle to push the toy out...you will not damage the hose.  If that doesn't work, you can use a piece of stiff wire fed through the hose with hooked end.  An electrician's fishtape...a snake...is often useful.
Nov 15, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Vacuums Logo
27 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
