Question about Home
My water was off due to new loo installed if my water pressure isn't right would that cause my shower to run to hot
    Top Expert:
  • Home Master
  • 43,014 Answers
There may be air in the cold water line. You should be able to release it by setting the shower to completely cold and turning it on full blast.
Posted on May 10, 2017
  • maggy1952
    maggy1952 May 10, 2017
    Thankyou I will try that
Loss of hot water during shower with an electric tankless water heater.
You are using the hot water at a faster rate than your tankless unit can provide. Either get a more powerful unit or reduce the amount of water flow thru the unit during the duration of shower.
Jun 20, 2017 | Jet Home
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
To adjust hotter
Your shower has been installed for a while and you are noticing the dial must be turned further and further to the hotter settings to get a normal shower - In this case the filter on the hot inlet is getting clogged with debris. Refer to the cleaning instructions in the manual that came with your shower, or contact Hansgrohe USA by calling 800-334-0455 for the documents.
If your installation is brand new or old, debris on the filter is the number one cause of this problem. You can test it by noticing if there is a drop in pressure when you dial to a hot setting as opposed to the cold setting. The drop in pressure indicates dirt on the filter where water has a tougher time getting through.
Filters on a shower valve may seem strange to US consumers. Your old two handle valve system woul run for years without needing servicing. Now you have filters to deal with. These filters, like any filter need to be cleaned periodically and the frequency depends on the quality of your water supply system.
The real benifit, is that the filters protect your smart valve and the shower head from malfunctioning due to debris.
Aug 31, 2011 | Hansgrohe 06642000 Chrome Solaris Single...
A plumber has just installed a shower which has uneven water supply pressure. The low pressure hot water from a head tank had a 3/4" pipe supply whichin spite of being questioned the plumber has reduced...
You aren't the first to run into this dilemna.
The size of thhe pipe will affect your system in this way.
If you start 85lbs of pressure in the water main, The meterhas a 1" pipe inlet and a 3/4" outlet. The meter reduced thhe pressure to60 psi and then it is reduced again at the point of entering the structure dropping to 1/2" pipe. By resucing the pressure is upped approx 5-7 lbs. The point of regulator and pipe size is the only time the pressure changes. The lowest pressure will drive a rainbird spribkler,actually several. But too many rainbirds won't affect by pressure as much as volume. The pressure will push whatever is available.By reducing the 3/4 to 1/2" didn't affect your pressure as much as it did your volume.. The reason your hot water starts to run cold sooner is that now you do not have the volume ratio between the cold and hot.It 's 1:1 now instead of 1.25:1. Hot more than cold. It takes more hot water to heat cold water than ittakescold to cool hot. Plus, the hot water you use is being replaced by cold water and that water is cooling what hot water is in the tank as the heat moves to the cold. The heater cannot heat al that water fast enough, but the cold water line is happy as can be.No pressure changes and no temperature changes. Before, you had to turn up the cold to bring the temp down to comfortable or safe. I just had my shower redone and everything is the sme size. Here is something to think about. Ck the shower head. They clog up and cause poor mixing over time. Yoou should be ok. How old is the water heater? Over time they get a build up of calcium and lime which is very detrimental to the heaters efficiency and recovery time. I hope this all made sense to you. At times when we have things done right it seems to be wrong because we are accustomed to the way it was. You will get accustomed to it and find your water heater gobbling less energy. Good luck and I hope it all works out, There is no need to fret. Sincerely -Ned-
May 21, 2010 | Home
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Pressure is high can it be adjusted?
Is this a new install? Is this happening with cold and hot water, or just one? Is it just happening with the shower valve open if it's not a new install. it may be the shower valve bad. These can be replaced easily, Lowes $7-14 depending on brand. The water has to be shut off from coming in to the shower. If it is happening with the water running on either hot/cold, the each one has a valve like the shower knob. These go bad and are replaced the same. These release to much water when the rubber seal breaks down inside the valve. Let us know which way it's happening and maybe able to help more.
Jan 02, 2010 | Delta & Single Handle Shower Faucet
I installed a new Delta shower valve. When I turn the handle to mix the warm and hot water it vibrates like a jack hammer. Is the water presure to high or is the valve bad.
It is due to the water pressure. You may need to install
a pressure relief valve at your main cold water line, so
you can set the water pressure and prevent your valve from vibrating, that is it it is annoying you,.Otherwise,
just let it be..
Nov 10, 2009 | Delta Lewiston Tub & Shower Faucet
At certain settings the shower shudders. Not air in line as it only happens at certain temperature settings.
That problem you described is called "hammering" and usually happens in older homes that don't have anti-hammer tubes installed on the water valves at each device (sinks, toilets, showers, clothes washer, etc.) When the water is turned on the sudden flow increases the pressure in the lines and when the valve(s) are shut off, you'll get a loud banging sound.
In the case of the shower, it is likely due to the hot water and cold water lines cavitating since cold water is also entering the hot water tank to replenish the hot water you're drawing out at the shower.
It's not economically feasible to go back and rip open all the walls behind every plumbing faucet in your house to install anti-hammer tubes, but you can install a small expansion tank on the main water line where it enters your house to help absorb the pressure variables along with a 18" long "bang tube" that should help eliminate the pipe shudder you're getting.
You might want to get a plumber to look at your particular situation, as it is difficult to be 100% certain as to what exactly is causing your dilemma without seeing and hearing it firsthand. I've provided possible reasons and solutions based on my experience with similar situations.
Hope this helps and best regards!
Aug 03, 2009 | Graff G-7065-LM15S-P ; G 7065 LM15S P...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
44 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
