There is a long black line going down my screen
I have a TH-PX60U that has a black line going down the front of the screen. It goes from black, then back to regular color. The black line keeps coming back. How can I get rid of the black line??
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 08, 2015 | Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Jun 08, 2014 | Samsung Televison & Video
How to fix black line down the middle of screen?
Unfortunately, if it's a black line that covers what is being displayed on the screen, no matter which game you insert, it will not go away. The screen has been damaged and V-Tech says it cannot be repaired. My 2 children have Mobigos and both of them have damaged the screens now to where there is so much black that they can't even be played... waste of $!
Feb 27, 2011 | Vtech Mobigo Learning System
Blue Screen, Zig Zag Squiggily lines, black sceen and freezes
No, try to call the HP tech support for possible repair. call at 1-800-474-6836
May 09, 2010 | Computers & Internet
I have an inspiron green lines running down the start up screen
You need to try to log into safe mode. if its running win xp please hold the f8 key down and it should prompt you to go to safe mode. If safe mode lets u in all the way. you need to update your video drivers.
Apr 15, 2009 | Compaq Presario M2000 Notebook
Black lines 1/8 of an inch apart going down my screen when playin
I had this happen a few times, then after a while it stoped working all together. In the end I was getting the E74 message code appear when I turned on my xbox 360.
You'll probley get this happen with yours soon, the E74 code means theres a problem with your visual display.
Sometimes it can be as simple as changing your HD Lead or scart lead, whatever your using. If you know someone else with a xbox try theirs.
If this doesn't work you'll have to send it off to mircosoft, it will be free if your still under warrenty, if not I think it's about £100+
Or you could go on www.cd24-7.co.uk and buy one of their DIY kits.
Hope this helps.
Jan 11, 2009 | Microsoft Xbox 360 Console
Thin Black lines going down my screen, sony Wega Ke-42TS2
These sets are common for bad connections on the ribbon cables connecting the screen to the drive printed circuit board. Or the drive circuit could have a bad drive scan IC. I doubt that but possible. Your going to need to call an AUTHORIZED sony repair servicer to trouble shoot this for you cause any other shop may not have a clue of this problem. Good Luck
Aug 08, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
