This video may help. First you must see if it is a fuel problem or an electrical problem. Spray a little starter fluid into the throttle body and see if it starts. If it does, check fuel system pressure. If no pressure check fuel pump for operation. If it still does not start then there is an electrical problem which could be anything from a module to a fuse.
I have a question for you in order to be able to better help. Is there what appears to be a plumbing vent cap in that area? If so that is most certainly where your satellite prep cables are located. If not can I get a picture of the roof?
? 11:40
https://www.youtube.com/watch?v=7nsTuFfPZLE
Jan 17, 2014 - Uploaded by Parkwayrvcenter
Can you find Holiday Rambler Quality with a Slide Out and Low Miles for ... Normally that is impossible but Parkway RV Center has done it again ... ... Remove all; Disconnect ... 1999 Holiday Rambler Endeavor 36 WGS Class A Motor Home with .... 1997Holiday Rambler Vacationer class A gas motorhome ...Missing: house
