Question about Jet Saws
Jet table saw 3hp, low torque! New saw, correct electrical hook up, but not much power at the blade, so yes it runs but no torque! mag switch in test position, does it need to be in auto???
I just bought a jet table saw 3hp, it runs but doesn't seem to have any torque, almost like running a 1 1/2 hp. Now I'm not a newbie to electrical, the circuit I use is a 20amp 220, that runs my 220 compressor no problem, but the saw boggs down with just a sheet of 3/4" plywood, even though it's a sharp blade.. Tech support at jet ..well,..after an hour of waiting on hold nobody came on the line to assist, (so much for tech "support"!) ..opened up the mag switch, it has a dial that is pointing to test, vs. auto, should it be on auto? does the test position only allow one leg of the 220?
  • 55 Answers
I am not sure what model you have but they have this saw in two models one is 230 volt only the other is 230/460 volt.
But that is not a 220 volt circuit. 220 volt is single phase where the 230/460 is a 3 phase circuit.
Look on your motor and see what the power requirement is.
if you have a different machine then the one I am looking at I would switch over to the auto function.
Posted on Sep 02, 2017
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
Posted on Nov 30, 2008
  • 58 Answers
SOURCE: which table saw
I work in the carpentry shop for the Metropolitan Opera.  Part of my responsibilities there are to maintain the shop tools which include several table saws.    First I will say that your choices are both good. The models you have chosen are both shop quality, heavy duty, production models.  These are not your cheapo underpowered consumer or even pro-sumer quality saws.  These are professional quality, one per lifetime tools.  The decision to buy one of these saws new is one that calls for insight and experience.  Take into consideration the size of the room in which you will install the saw.  Consider which one is easier to change the blade.  Will you be cutting a  variety of materials or just pine?  Does the work you want to do involve repetitious jobs requiring jig set ups or are you just doing general carpentry?     Well I think I can give you a few things to think about before making a life-long investment such as one of these.   Based on all the internet reviews and specs I found, the Grizzly is a better value and the company gives very good support.  The ergonomics of blade replacement, fence operation, and on/off switch placement are the most important factors in regular use.  The fact that Grizzly gives great customer support rates very highly in my book.  In its price range the Grizzly is one of the best values and that goes a long way when you have to buy accessories to accommodate your needs for the tool.  The choice is clear to me...Grizzly.     Some other things mentioned in the reviews of the Grizzly.  A blade wrench is not provided with purchase of the new saw.  Contact the manufacturer when you decide on the other accessories you may want.  The table and other non-powder coated parts are shipped coated with cosmolene, a protective petrolium oily wax coating used to also protect guns.  Apparently cosmolene is best removed by heat (140 degrees should do). Wrap the parts in absorbent rags or newspaper and place in a tent made of a garbage bag and run a blow dryer into it for about 30 minutes.  Then remove the rest physically with rags or spray with WD-40 and wipe.  The lower the heat temperature the less the smell of the cosmolene persists.  Without reading up on cosmolene removal my first choice for removal would have been Goo-Gone or Goof-Off graffiti/gum remover, which is the least toxic solvent for petrolium waxes.   Leave yourself plenty of time to set up your new saw,  and consider its weight is considerable when traversing stairs and such.  You should not have much difficulty as all the reviews give Grizzly the highest marks on ease of accurate set-up.  Good Luck!
Posted on Jan 05, 2009
  • 1055 Answers
SOURCE: 1998 Chevy Cavalier-electical
youve either got a bad connection at the new battery or the power wire is shorting out did he have too pull the cables too get them too fit?
Posted on Feb 27, 2009
  • 400 Answers
SOURCE: hp cp2025 leaves marks down left side of printed
Also change the toner cartridge or image drum(if it has one)
Posted on Aug 28, 2009
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
I have a Powermatic 2000 table saw. The power is good but the saw won't turn on. It has a magnetic switch with a double of circuits inside. do I need to replace the whole switch assembly ($172) or is there...
prob just motor starter. remover power from mag sw and o/l from bottom of mag sw. meter L1 to T1 for continuity by pressing button in center of mag sw. do this for all L1,@ and # to T1, 2 and 3. if all good check for resistance in coil..A1 to A2. replace with new by taking part to electrical wholesalers.
Dec 15, 2013 | Zazzle Powermatic 2000 Table Saw T-shirts
On/off switch just buzzes when I push start. I can't find a reset button on the JET XACTA SAW DELUXE 3HP,1PH, 50" RIP table saw. It's getting electricity- plugged in and continuity of...
I am thinking that you have a problem with the capacitator (if it has one) or the starter windings/switch in the motor itself. If the switch buzzes you are getting electricity to the motor but it isn't rotating and that is where I would start to look. Before this happened did the saw make any unusual sounds or have any problems??? Also unplug tool and look for any obstructions that might have stopped the blade.
Jul 02, 2011 | Exacta DELUXE XACTA SAW 3HP, 1Ph, 50? Rip
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
Oct 20, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
Jet saw Manual for a JTAS-10/12
Jet's Manual site is here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is here though.
If this helped, please vote. Thanks!
May 25, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
The blade spins to fast and torque is very low. What do I replace
If this is a belt driven saw, maybe the pulleys on the motor and arbor are reversed? If both pulleys have the same size hole and the one on the motor is larger than the one on the saw arbor, then you should switch them. This will lower the RPM and increase torque.
If this is a direct drive saw (the motor shaft is the saw arbor) then the only recourse is to use a smaller blade.
Feb 17, 2010 | Bosch 4000 Factory Reconditioned 10"...
I own a Jet Left Tilt Cabinet Saw Mdl 708663PK. The on-off switch seems to stick and does not always start the saw. The saw runs normally when it starts. When it does not start, the on switch depresses and...
I took the front cover off of the switch and noticed the portion of the switch the off button contacts was fully depressed and would not slide back to its proper position. I lubed (silicone) the slide portion of the off switch and cycled it manually to free it up and distribute the lubrication.
Feb 17, 2009 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
On/off switch
The contacts in the switch are burnt, replace them.
Sep 21, 2008 | Jet 708715PK/JTAS - 10X50 - 1PK 3HP 1Ph...
Saws Logo
288 people viewed this question
Top Jet Saws Experts
Are you a Jet Saw Expert? Answer questions, earn points and help others
