Question about Sony Computers & Internet
Sharp knee mill with Sony NU-20 controller
Good afternoon, I am in possetion of the above stated machine. Last week when attempting to turn on the machine everything appeared normal until the dialog screen of Send Data appeared. The dialog box said send data now NUMBER:51 BLOCK:1. The system will just sit there unless cancel is pushed. Pushing cancel will abort the parameter send and launch Sony Millgen however none of the features on the MPG will function, in addition no zero return moves can be executed.
SOURCE: Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Posted on Apr 15, 2008
SOURCE: Lost Memory and Map Data
I just spoke with Garmin and they walked me through correcting the problem - very helpful. It is a matter of resetting the unit. Turn unit off, then press a finger tightly against the bottom right hand corner of screen, holding it while turning unit on. When screen comes up, let go of power button but still pressing bottom right hand corner of screen, answer question regarding deleting defaults. It is tricky and may have to be done a couple times. Then you will answer questions regarding time zones, etc. When finished with this, turn unit off and go outside in order for the unit to re-aquire satellites. When all four bars on upper right hand corner turn green, you're back in business - or at least it worked for me. Hopefully this will help, but you may want to call Garmin as they are really helpful and can explain it better than I can. Good luck!
Posted on Jul 09, 2008
SOURCE: dbx Driverack PA LCD problem
I just read in another forum that the LCD display appearing black (but backlit) could be due to the ribbon connectors being loose behind the screen.
You would have to open the unit to check...
However, this would most likely void your warranty if your unit is still under one.
Hope this works...
Posted on Sep 25, 2008
SOURCE: Casio KL7200 label maker Message:
Press any key other than "on/off" to clear the DATA ERROR off the screen. Then, the screen will say "initial". Press "set"
Posted on Jan 12, 2009
jell587
  • 447 Answers
SOURCE: screen comes up stating; self monitoring system
The error refers to the SMART system (read more about it).
Your hard drive may be getting ready to fail or you may have received a false error message (which can occur). If possible go into the bios/CMOS and disable the SMART system so that you may be able to boot normally. Once booted you need to make a backup of your data immediately.
If you are unable to boot the machine even after disabling SMART you may need to replace the hard drive and hook the old one up either externally (the preferred method) or as a slave so that you may backup the data on it.
Posted on Mar 02, 2009
My new Bernina 880 will not turn on. I have been using it daily for the past week. Last used yesterday afternoon. This morning it will not turn on.
You might try a different electrical outlet in the house or check the one you plug your sewing machine into to make it is still working. Hopefully, there wasn't an electrical surge.
Apr 18, 2018 | Bernina Sewing Machines
Engine turns very will but will not start
if the fuel is getting there something to do with the spark. Are all contacts good and clean? check the quality of the spark....see if it is any good.
Jul 19, 2015 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Vh3 sharp milling machine
That may take fiddling with several of the controls around the head... you'll need to experiment with it.
May 27, 2013 | Tools & Hardware - Others
I have purchased a kenwood FP270 food
not sure if this helps, but we bought the same FP270 11 months ago & use it 3-4 times a week with juicing attachment with carrots & apples. Last week the motor started to smell, and motor burnt out completely today with dust & noxious smoke coming out of the bottom. The Good Guys exchanged it for FPM270 with no hassles under warranty. I don't think the motor is powerful enough for serious kitchen work & had many cracks in the plastic parts.
Feb 17, 2011 | Kenwood Food Processors
Good afternoon sir here i want to know how to get dealership of sharp mobiles in india and and in andra pradesh state
go to net n find the site over dere n get all details n contact dem 4rm 4r dis solution.
Nov 23, 2010 | Sharp Cell Phones
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Computers & Internet Logo
77 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
