Question about Garden
Sounds like pebbles under cutting deck when blade engaged
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 941 Answers
Jack up the mower and see if you can turn the blades by hand. sounds like the deck may be bend and the blade is hitting the edge. you may also see a shinny spot on the deck where it is hitting.
Posted on May 11, 2017
Cutting blade won't engage
with unit off look under at deck and inspect cable and pulleys and belt adjust and or repair
Sep 28, 2016 | Garden
On my trroy-bilt lawn tractor pony i was in high grass it seem to stop cutting smoke came from the deck stop cutting the handle that engage the blade become reaaly easy to move nothing happened
It sounds like you got into a job that was too big for the machine, and you may have either burned up the drive belt, or toasted the transmission or clutch.
Someone knowledgeable about such things should be able to raise it up in the air and look underneath and discover which problem you have.
God bless your efforts.
Jul 08, 2016 | Garden
My craftsman DLT 2000 won't cut grass , the pulleys are clean n moving the blades are rotating but when I let the deck down to cut the grass it stops and sounds like the belts trying to turn, making the...
be sure the blades are not bent and you dont feel any wiggle when pushing them up and down. be sure nothing is wrapped around the spindles. be sure the belt isnt damaged and tight when the deck is engaged to cut with the engine off.
Sep 18, 2017 | Garden
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Troy bilt lawn mower
sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Jul 13, 2013 | Garden
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
