Question about Invicta Watches
HOW DO I REMOVE THE STEM FROM MY INVICTA LUPAH DIVER. i CAN NOT FIND THE RELEASE
VOTIT
  • 2071 Answers
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Posted on Jun 17, 2008
SOURCE: reseting invicta lupah diver chronograph
http://www.adamswatchblog.com/?p=97
Posted on Apr 12, 2009
  • 183 Answers
SOURCE: how do i set the time on an Invicta Lupah mens
The Lupah has a chronograph so dont worry about the sub dials while your setting the time. Pull the crown out to the first position and set the time. For the date pull out to the second position and set the date.
To set the chronograph sweep arm pull the crown out and press and hold down the start button. The sweep arm will move into position. Stop it on the 12:00 or 0 position.
Posted on Sep 18, 2009
escapement
  • 2334 Answers
SOURCE: i have an invicta corduba diver watch how do i
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 09, 2010
  • 2501 Answers
SOURCE: the screw on the stem of a invicta grand diver has fallen off
Without seeing the watch I cannot be sure if it is a DIY job.
'If you haven't already done so, I suggest that you take it to you local watch repair shop.
It could be quite simple but needing someone who is used to handling watches.
Threads can sometimes be fixed in position using a glue called "threadloc" , which, as the name implies, is a glue designed to prevent screws from becoming loose.
However with something as small as a watch, you need to be very careful how you splash it about, as glue in the wrong place could be a disastrous.
Posted on Feb 20, 2010
I am looking for a new watch band for my Invicta Pop Lupah 2397 (turquoise). Where can I order one ? Julie
Visit the Invicta site. Their posted price list has prices for what I would expect is replacing the original watch band .
http://www.invictawatch.com/invicta/price_list
If you do not have a local delaer whom you can visit to onbtain a new watch band information on how to ship your watch to Invicata can be found here:
http://www.invictawatch.com/invicta/shipping
Mar 30, 2011 | Invicta Lupah POP 2397 Wrist Watch
Can you give me a list of the three button functions and a describe how to get the sub dials to go back to zero? Thanks.
mcdevito75 here, Best Bet with your Invicta Watch, online to shopNBC.com then to Invicta watches, see if you can get an instruction manual. Each of those buttons may have a screw down cap to maintain waterproofing and one of those buttons will also have a double duty in the functions of your watch.
Jul 02, 2010 | Invicta 3209 Lupah Diver Watch
Self winding
Your watch is battery powered. It is NOT self winding.
Jan 21, 2010 | Invicta 3209 Lupah Diver Watch
Invicta Lupah crown replacement?
If there is no problem with the stem then you can just screw it on. I suggest using a thread lock to insure a good fit. Start by taking the back off and hold the stem in place with a pair of needle nose pliers. Be sure to start by turning the crown in the reverse direction so you dont cross thread. Once you feel it hit the beginning of the thread you can turn in the on direction.
I always recommend having this sort of service done by a watch maker/technician who can reseal the watch and pressure test it to be sure it is still water resistant.
Aug 30, 2008 | Invicta Dragon Lupah 2093 Wrist Watch
Invicta Lupah #2094
The Lupah is a quartz movement so try having the battery replaced.
Dec 26, 2007 | Invicta Dragon Lupah 2094 Wrist Watch
Watches Logo
44 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
