Question about Canon Office Equipment & Supplies
Toner caking ( stones) in drum unit of canon IR 6050 Can anybody suggest
  • 6 Answers
SOURCE: Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
Posted on Jun 02, 2009
  • 118 Answers
SOURCE: Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Posted on Jul 16, 2009
  • 134 Answers
SOURCE: where is the waste toner receptacle located on the canon IR 3300i
Lower rear right portion has a small vertical panel held by one screw. The waste bottle is behind this panel.
Posted on Aug 13, 2009
redzventures
  • 149 Answers
SOURCE: HOW DO RESET TONER DISPOSAL FULL,AFTER REPLACING ON A CANON IR 28
You have to enter servcice mode and reset the error code. Press the 'head' key with the star inside it - then the '2' and '8' key at the same time - then the HEAD key again. This must be done fairly quickly and then you're in the service mode. Now, from the screen select 'COPIER' then the 'FUNCTION' key then 'CLEAR' ---->'ERR' ---------> 'OK'. Now turn the machine off and on again. Your code should be gone. If not, you may have to clean the waste toner bottle neck where the sensor light shines through it.
Posted on Jan 20, 2010
Testimonial: "THANKS ALBERT"
  • 18 Answers
SOURCE: The print on my Canon
There is a possibility that there is toner burnt stuck on the fixing roller.
Posted on Dec 22, 2010
Yang dimaksud E000013-0000
I take it that you have a Canon copier? The error code means that something is locked up with the drive of the copier. On a IR 330 or 400 the problem is with the fuser drive or with a IR 5000 or that series will be the waste toner feed screw is not turning. It may be the waste toner screw in the drum unit is packed with toner... Or I believe there is a switch on the back side of the copier that is not being turned. It is not a pretty job... I would check the waste toner bottle and empty it out. Also, pull the drum unit out and try to turn the waste toner gears. If they do not turn then, break up the toner caked up and vacuum it out and reinstall and hope that it clears... Good Luck.... It could turn into a ugly job
Mar 07, 2013 | Office Equipment & Supplies
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
EO19 error
You have problem with waste toner, to be specific You need to empty the waste toner compartment in drum unit.
Open front cover and left side way door, on front side you will see the blue handle beneath the drum unit, lower her and pull the drum unit out. On top side of the drum unit you will see the cork which you need unplug and empty or vacuum the waste toner.
when you put all in first state turn off and on the copier.
Hope that helps!
Jan 10, 2011 | Canon iR 2016i Black and White Copier
Canon IR C3220N--error code E000020-01b0
If the drum units have been removed repeatedly without the drum guide service tool it's possible to break one or both tabs .These tabs open the toner hopper when the drum unit is slid in, and if they are broken, toner will not be fed into the drum unit.
NOTE: The unit may work for a while until the developer to toner ratio drops enough to cause an error.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Canon imageRUNNER C3200 Color Printer
Copiadora canon ir 2016 muestra codigo e19 y suena
The waste toner needs to emptied out. It is in the drum unit and you most likely need a new drum unit. But you can empty the drum unit and turn the copier off then back on.... Good Luck Amigo
Sep 24, 2010 | Canon iR 2016i Black and White Copier
Canon photocopier iR2016 displaying "waste toner full" on screen. How do I fix this?
Hi there you can empty the waste toner box wich is located inside drum unit.
The procedure is next:
open front cover and leftsideway door
release the blue handle above the drum unit
pull out the drum unit
on top of drum unit, near handle is located plastic grey colored cork
remove it and by means of vacume cleaner clean the vaste toner.
Note that if you flip out the drum unit and try to empty waste toner it could be messy and the toner can get into charge roller or on drum cleaning blade and then you need to change it completly.
hope that hepls
Aug 16, 2010 | Canon iR 2016i Black and White Copier
Where is the waste cartridge for the canon ir 2018
If you open the front cover and release the leaver of the drum unit.Remove the drum unit.On the drum itself is a plastic plug,remove the plastic plug and remove the waste toner in to a bin.The waste toner is stored behind the drum and must be removed reguarly.
Dec 14, 2009 | Canon imageRUNNER 2018 Copier
Canon IR3300 dark print out
You refilled the toner. Don't recommend refilling the toner. If you're going to spend the money on a copier. You should get genuine toner.
I suggest you make a service call and use genuine toner in future.
Aug 17, 2009 | Canon NP 6050 Copier
Canan ir 1018 make sound
Normally nise come from the drum unit when the waste toner is too full.Remove the waste toner by removing the drum unit and remove the waste toner plug and disgard the waste toner and reinsert the drum unit.
May 18, 2009 | Canon imageRUNNER 1023iF Black and White...
NP4050 EO2O ERROR
The error code means that the toner level in the developing unit is low. The ATDC sensor is probly bad or it is caked with toner and it is not reading correctly..... Good luck finding one.
Jul 09, 2008 | Canon NP 6050 Copier
26 people viewed this question
old marine
old marine
