Question about Cub Cadet Garden
I pushed the transmission bypass rod back in but the xt-1 cub cadet transmission will not engage so i can mow. its like it is still in bypass mode. is there someone there?
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 376 Answers
SOURCE: 46 inch cub cadet mowing deck
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
Posted on Jun 11, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
Mowing deck locks when engaged to mow so what could be the reason ?
is something under the deck locked up against the blades?
May 01, 2017 | Cub Cadet Garden
Cub Cadet 1045 hydro. Transmission not working. Bypass rod in. PTO and belt fine. Jacked up wheels spin in opposite directions. Forward and reverse pedal when pushed makes loud grinding noise.
This actually sounds like the top pulley on the transmission may be loose and the center hole worn out.
Depending on the actual sound though it may be a bad transmission - sorry. I suggest having a dealer mechanic inspect it.
Mar 04, 2017 | Cub Cadet Garden
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
Oct 11, 2015 | Cub Cadet Garden
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
I have a LT 1024 series 1000 Cub Cadet lawn mower. The PTO shuts off when I'm mowing the lawn. It will run ok if I use the cruse control. I was told it might be a motion switch. Where is this motion switch...
There should be 3 safety switches on the mower. 1 will be under the seat, causing the engine to die if you were to fall off the machine while in gear. 1 is in the transmission to be sure the machine is in neutral when you go to start it, and one will be on the blades to insure they are not engaged when you go to start it. You will not want to bypass this switch, rather get it replaced as it is very important that this safety feature is working should you slip off the seat or accidentally get off the machine when it's in gear.
Feb 17, 2010 | Cub Cadet Street Sign- tractor lawn riding...
The pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Sep 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
35 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
