Question about Garden
I think my belt came off my 42 inch poulin riding mower Clutch wont engage and therefore wont go into gear.How do I get at these belt. Take mower deck off?
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
Posted on Jun 01, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
What size belt for powr kraft 18/42 industrial commercial twin cylinder automatic hyrostatic dive .need deck belt.
My mower is 18/42 power kraft, limited addition, hydrostatic. I need to replace deck belt because deck belt was bitten by mouse. May I know belt routing and how to replce it. Thank you.
Jan 28, 2012 | Garden
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @
May 30, 2011 | Troy Garden
I have a bolens 38 inch riding mower. it cranked and when i tried to engage the cutting deck the belt smoked off. i replaced the belt and cranked mower. tried to engage and belt smoked and i shut it off....
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Feb 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower Belt Won't Engage
The fact is that belts don't stretch. They wear down on the sides, causing them to ride deeper in the pulleys and they APPEAR to be longer. Check belt "width" to see if it is less than one half inch. Most craftsman riders use half-inch (AKA: "A section") belts.
Sep 26, 2009 | Garden
Blades don't engage
Check the drive belt for the blades
Jul 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 inch poulan belt broke on mower deck diagram to replace new belt
Jun 14, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman 42 inch deck won't run
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
