I have a accer 32 inch tv modl number att3220a will not powe4 on have checked the pug and checked the switch and they both look goood and have changed the power cable
bhur
  • 85 Answers
SOURCE: 32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
Posted on Jun 13, 2008
  • 4090 Answers
SOURCE: MY TECO 32 INCH LCD TV HAS NO POWER MODEL NO
sometimes if the temperature builds up as a result of being too close to a wall or some refelective heat source the unit will auto shutdown .Also vacuum the air holes on the casing, if these are clogged the prpoblem will also occur. Failing that being the problem there is a fuse inside, but it may be easier and safer to get a callout tech to open an fit this
Posted on Aug 12, 2009
  • 2336 Answers
SOURCE: My Astar, 32 inch TV, does not turned on. I
Check this link to find the power regulator.
Posted on Feb 23, 2010
SOURCE: Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Posted on May 03, 2010
gopakumarg43
  • 75311 Answers
SOURCE: the 32 inch will not do a channel search and I
Hello
The system memory IC of your tV has damaged. This IC stores all the data the set will have when we switch it OFF; and retrives that data to main system IC when we switch it ON, and get processed. It otherwise called as an [EPROM] IC (Erasable Programanble Read Only Memory). Even though it is very small in size and very cheap to buy, its function in Tv circuit is great. It is an 8 solder terminal IC, can be located very near to the main system control IC. Replacing it will solve the problem of your tV. OK.
Posted on Jul 16, 2011
What is causing the black screen and 3 blink light?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 16, 2014 | Panasonic VIERA TC-P60GT50 60-Inch 1080p...
Sony wega kv-32FQ86B flashing light
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv switches on goes from red led to green and after a few second goes back to red. No picture 32 inch aquos
Dec 30, 2013 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Have a sansui tv model number dtv 2798 32 inch i
Check and replace damaged component/s at its main power regulator section circuit. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 18, 2013 | Televison & Video
Cracked panel on 32 inch
To get a new LCD panel will not be worth it since it is limited production run, it will cost more than the TV is worth, you can contact www.shopjimy.com to see what he has in stock but you need to the get the modle number on the tag of the LCD sceen to get the correct one since same model can have diffrent LCD panel installed.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 01, 2010 | Protron PLTV-32 Television
RCA TV GEMSTAR GUIDE PLUS GOLD
what is this TV's modle #?
Aug 24, 2008 | RCA F32650 32" TV
Fron TEDted
What is the manufacturer of your set I cant get any inforamation what so ever by using the model number.
Apr 09, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
