Question about Maytag MAH2400A Front Load Washer
We have a front loader MAH4000AWW and it sounds like the discharge pump is going bad. It is making a gravel sound when it is pumping the water out.
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 517 Answers
Take the plug/power lead for the machine OUT so machine no power then.
safety first.
you need to clean the filter and also may need to take the pump to clear it
Posted on Jul 25, 2009
Aux light flashing and pump is pulsing
The Pump pulsing is sounding like maybe there is not enough water in the spa to keep enough water to the front of the pump.
This is called 'cavatate" and is caused by lack of water to the front of the pump.
Also check the gate valves in front of the pump and the other side of the discharge of the pump to make sure they are completely open.
The Light issue sounds like maybe a relay on the circuit board could be bad or the transformer for the light is going out.
RodUS Parts Center888-521-6813
Mar 01, 2013 | Qca Spas Pool & Spa
My front loader won't spin - the machine makes a noise when it is supposed to spin but nothing happens
sounds like a bad pump open the sumpm on the lower left side (preapre water to gush out if still in the tub) check if there is any objects in the pump or sump if yes remove and try if not replace the pump
Sep 02, 2011 | Asko W6021 Front Load Washer
Maytag Neptune MAH4000AWW Front Load Washer Washer will not drain.
Sounds like an object is stuck in the pump. Does the pump activate? Does it try to pump out water. Please let me know.
Jul 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do I hook up a sump pump do it go to a drain or out to the lawn.road
Most areas it is not up to code to discharge stormwater into a public sewer. In other areas it is not permitted to discharge into street. This can errode the streeet and causing freezing. There is a pop up device to allow you to discharge into your yard. It will pop up when pressure lifts it allowing the water to discharge in your yard. Be sure that the water doesn't flow into a neighbor's yard. You will have to make provisions for the outlet to drain in the winter. I would keep the pipe below frost line. Where pipe turns up I would drill small weep hole and back fill area with sand or gravel to allow the pipe to drain when pump turns off.
Oct 06, 2010 | Do It Best Column Sump Pump
Bad pump??? Bought used and did a few loads OK but lots of sand/small gravel came out discharge. Fifth load would not drain basket. Error code said drain failure. Went to troubleshoot/diagnose mode and...
Is this a FAV6800A or FAV9800A machine? I would normally ask for clarification but I can’t post a pic with a clarification question. I’m an owner of a FAV6800A.
I assume the error code was “ND”.
Did you open up the pump housing to expose the impeller? Make sure it hasn’t broken loose from the motor shaft and is freewheeling.
Sounds like you have checked the Sump Cap for any clogs and drain hose to drain pump for a clog.
If your machine is not a FAV6800A or FAV9800A then please disregard my solution please don't vote on the solution.
This forum doesn’t require Machine Model Number or Serial Number which is a big mistake.....Rich
Jan 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Machine will not empty water, new pump installed today still no joy any ideas
Whether a front loader or a top loader, you are probably missing a sock. My guess being a sock or similar sized article has escaped the tub and is obstructing the water discharge to the pump. How to get to it depends on the top loader/front loader/make/model thing.
Dec 18, 2009 | Washing Machines
Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
May 16, 2009 | Washing Machines
Maytag MAH2400A Front Load Washer Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
