Question about Cub Cadet Garden
I pushed the transmission bypass rod back in but the xt-1 cub cadet will not move.
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
retort
SOURCE: cub cadet weed eater wont stay running
air vent in gas cap pluged, push a pin through it
Posted on May 28, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
SOURCE: the pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Posted on Sep 23, 2009
Cub cadet sltx1050 wont go forward or backwards? was w orking fine then we had to push it backwards to jump iot cause it wouldn't start and now it wont move forward or backward
There are two possible options one is the belt for the drive is shot, the other is that the transmission is shot we tend to go out.
Nov 08, 2017 | Cub Cadet Garden
Cub cadet tank wont move once releasing the parking brake
Not sure what you are trying to do, but in order to push a Cub Cadet (when its not running), you need to put the transmission in ANY gear other than Neutral.
Jul 22, 2017 | Cub Cadet Garden
Cub Cadet 1045 hydro. Transmission not working. Bypass rod in. PTO and belt fine. Jacked up wheels spin in opposite directions. Forward and reverse pedal when pushed makes loud grinding noise.
This actually sounds like the top pulley on the transmission may be loose and the center hole worn out.
Depending on the actual sound though it may be a bad transmission - sorry. I suggest having a dealer mechanic inspect it.
Mar 04, 2017 | Cub Cadet Garden
Cub cadet i1042 zero turn doesnt seem to want to go forward when turning or even going strait sit moves very slow and when i go up a little hill it stops half way and then creeps up the hill it use to
If it's a hydrostatic transmission, I would have the transmission looked at. You may need to "purge" the system and check the fluid level.
The ones I've done called for the drive disconnects (the rod or lever which allows you to roll the tractor when the engine is shut down) to be in the flow bypass position. They also wanted the wheels off the floor, then the engine to be started, & the direction control to be worked SLOWLY to the front & rear positions 10-12 times. Then put the bypass valve back in its 'drive' position, fire the engine again & repeat the slow cycle of the direction control. The unit SHOULD be quieter now & perform better, but double check the oil level because expelling the air may have dropped it too low.
Jul 22, 2014 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
I own a Cub Cadet Hydrostatic Lawn Tractor, not sure of the model # (either LT1042, LT1045, LT0146 or LT1050). The engine runs, blades spin, but it doesn't move forward or backwards... Looking for...
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Mar 07, 2011 | Cub Cadet Garden
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Mar 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
103 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
