Question about The Computers & Internet
After pushing the transmission bypass rod back in the machine will not move
Its like its still in bypass mode.
4 Suggested Answers
coehspprobe
  • 17 Answers
SOURCE: push rod order
when you take them out it's a good idea to keep them in a certian order that you will remember but im guessing that you didnt. its not really a big deal, just put them back in however it shouldnt hurt anything
Posted on Feb 24, 2009
philwalker78
  • 608 Answers
SOURCE: I have a Husqvarna 2754GLS lawn tractor. I pulled
Rock the tractor back and forth by hand as you push the rod in. Regards Phil
Posted on Apr 15, 2011
dttech
  • 4803 Answers
SOURCE: how do i remove lifters in 02 impala
Your push rods are different lengths. The intake push rods are the shorter ones and are marked with yellow paint. The exhaust push rods are marked with green paint. Double-check to make absolutely certain that you have them all in the correct position. (failure to do so will cause IMMEDIATE severe engine damage when the starter is cranked.)
Other than that, it is common for the lifters to leak down when the engine has been disassembled. I have even had several that made it very hard to start and "clattered" for like 5 minutes after starting the engine. It will be OK when the lifters pump back up.
Posted on Apr 24, 2012
How do I get the mower to push easier even after releasing the bypass rods?
Your transmission may have been compromised therefor preventing axle movement. Use moving dollies under the wheels to make moving easier.
Oct 10, 2014 | Craftsman 26 gross HP 52" Zero Turn...
Pedal is free- mover does not move
Two possibilities to look for.1. The linkage may have lost a connecting pin. Follow active rods from pedal to control arm on transmission. 2. There is a disengage rod to allow the machine to be pushed without the engine running. If this is in the disengaged position the transmission will not drive. Look at the rear and low down for a lever or rod which is connected to the transmission.
Sep 28, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
The mower can be pushed,but it locks rear wheels.If you pull it a few feet it frees up again. The rear wheels are locking up. Motor runs great.When you move the steering arms there is a resistance lik
I assume that this is a hydraulic drive. These usually have an isolating rod which has to be pushed in or pulled out, depending on model, before manually shifting machine. This opens a bypass valve which makes the drive ineffective. Check that this rod, which will be low on the rear of the machine, often on the left hand side, has not been moved. Try moving it and see if this is the difference.
Aug 26, 2014 | Garden
My craftsman yard tractor all of a sudden will not move, 42 " cut , 15.5.hp kohler motor Hydrostatic drive ,!
bypass rod pulled out to allow pushing the tractor, the noise is the hydrostat bypassing fluid (normal) if my crystal works
Apr 01, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
Hydrostatic transmission will not engage
Hello and thank you for choosing fixya. Many times when your hydrostatic transmission will not engage, it could be due to a loose, worn, or broken belt.
Check to see if your belt is still around all of your pulleys. Also, check to make sure that your belt is tight. Your mower has a bypass rod. This is the rod that you pull out, in order to release your bypass lever on your transmission, when you need to manually roll your mower. Lets make sure that this rod is fully releasing.
Double check your axles. If you have recently removed one of your rear wheels, and did not slide the square key, back into the keyway on your axle, this prevent your mower from moving when you engage your transmission.
Feb 06, 2014 | Garden
Rider will not move when in gear, forward or reverse
If it has an external brake on the side of the transmission, make sure this is not binding, you can check this by putting the machine in bypass ( push mode ) you should be able to push the machine readily, if not the brake needs slackening off.
May 12, 2012 | Garden
I have a 15.5 h.p. lawn tracctor with a hydrostatic transmission. I bought it from an older gentleman who serviced it religiously. It is a 2005. The transmission whines some which I understand is normal,...
Most hydrostats have a internal, or external disc brake it is very important that the brake is not adjusted too tight, follow the linkage from the foot pedal to the gearbox, slacken off the brake rod, so as when you put the hrdro in bypass ( push mode ) you can push it easily, if you cannot oush it the brakes are definatley binding.
Feb 05, 2011 | Garden
Its an automatic transmission and it stopped moving. I cant move forward or move backward.
make sure the neutral rod is pushed all the way in. the rod is in the back of the tractor.
May 25, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have just bought a ride on Electrolux mower and can start it but it want go forward. What havent I done to make it go?
I presume this is a unit with the hydrostatic drive (automatic, just step on a pedal). There should be a rod or lever, usually on the back of the mower, that will release the hydrostatic and let you push the mower by hand. This basically bypasses the system, and the mower will not move if this lever/rod is pulled. If someone had to push this mower to load or move it, chances are it's not been pushed back into operating mode.
Dec 23, 2009 | Garden
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
