Question about Weedeater Garden
Weedeater we261 wontmove hear a grinding sound took apart looks like drive chain is ok gears dont look ground down
    Master:
  • Weedeater Master
  • 645 Answers
This transmission is a really bad design the clutch pack is the problem. You can try to tighten it and get some life, but there are no fixes for this unit.
Posted on Dec 13, 2017
  • 350 Answers
SOURCE: 1999 chevy 4wd
hi sounds like a bearing worn on one of the shafts causing a mashing of the gears sorry needs overhaul yates210456
Posted on Oct 13, 2008
SOURCE: poulan/weedeater self propell not working
Poulan/weedeater Model#we6452se serial# 030497m 000378
Posted on Oct 24, 2008
SOURCE: big noise when in 4x4 on corners
I'm betting you will be running into a problem I am dealing with shortly. I would advise you to check your front axles possibly the transfer case as well, luckily you can drive straight in the 4x4 mode, mine grinds as soon as i move the lever, it might not be the wheel bearings, however it could be the CV joints, and if that is the case you may want to look into swapping your axles out. I'm not a professional Jeep guy but mine has had almost every problem it can have, just some advice, hope it helps.
Posted on Mar 30, 2009
  • 19 Answers
SOURCE: little tikes princess battery power wheels
I would replace the gearbox, but it is a specific little tikes gearbox. If it is making a grinding noise, then the gears have broke.
You can find them at this website
http://www.shopjandl.com/884931300.html. I would just let them know what model it is and you should be good to go.
Posted on Apr 27, 2009
  • 420 Answers
SOURCE: noise in trans or in primary chain
It sounds like the primary drive chain is loose. The way I adjust mine is to take off the upper left inspection cover, start the bike and slowly tighten the adjuster until it starts to wine, then back off until it stops. Rev it slowly and listen for a wine. No wine good to go.
Posted on May 07, 2009
Pulsar 150 drive chain jumping with strange knocking from engine.
Hi,it sounds from what you are saying that you have got a inturnal falt with the gearbox,im affried the only way to make a propper diagnoses is to take it apart and look at the gear sincros there has to be worn bearings,or teeth on the gears,or the sellector,or something has just manidged to come loose.
I wish you all thhe best.
Mar 07, 2015 | 2011 Bajaj Pulsar 150
How come driv chain comes off when you shalf gears Is transmissiom lose? Is bearings bad in shaft that chain goes around ? I need a diagram of transmission HELP!!!!
i would look for the chain is bad and or are bad spockets worn down chain jumps off when shifting replace these parts let me now and wheel go from there cost 50.00 to 100.00 if you can find parts go to dealer tell what you need andhe will tell you if they cane get it thats a lawn mower dealer
Sep 04, 2014 | Husqvarna WE261 960220007 26 190CC Weed...
Need information on fixing steering on we261 riding lawn mower.
you will have to pull the front wheel steering spindells if they dont have grease fittings and grease them
Jul 17, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
I want to know what the symptons of a bad torque converter are?
Your torque converter sounds like it has come apart internally
Jun 30, 2014 | 1998 Ford Explorer
Metal on metal sound from front end
May Sound stupid but I would check for gravel.
Feb 18, 2014 | 2000 Chevrolet Cavalier
Grinding noise when accelerating
HI If your bike is chain drive, look at the chain tension, the chain could be hitting the gear box case. If you primary sprocket is worn the the chain could be jumping teeth If you have a shaft drive then inspect the universal joints and the differential oil level
Feb 02, 2014 | kawasaki Motorcycles
Service manual
Any time I hear that complaint I cringe. Not because of the noise but what it might be telling me. I usually hear that noise as the hot roller bushings &/or the main gear that drives the fuser is cracking or already cracked and is ready to fail. This causes the roller to bind up hence, the grinding noise. Sometimes a drum can seize and that will also make that sound but if you're able to print OK that is probably not the issue.
Oct 24, 2013 | Epson ACULASER CX11NF All-In-One Printer
Grinding sound when riding but not idleing
Have you tried driving it next to a block wall? The echo off of the wall is great for narrowing down strange sounds..
Jul 13, 2017 | 2005 Suzuki GS 500 F
I have a Toro personal pace mower. Model 20017 The propulsion system isn't working. If I lift the mower, the wheels will spin, but back on the ground it won't propell the mower. I just put a new...
im assuming you dont here any grinding, start by tightening the cable ( loosen the cable mounting bolt slide the cable towards the engine, make sure you leave some play in the cable so its doesnt engage constantly and re-tighten ) this is most likely your issue however if you re-test and get grinding you either need new drive gears and wheels, new transmission or possibly both, you said it does something just not powerfully this pretty much rules out your belt, highly doubtful its that worn out and if it came off of a pulley it would do literally nothing, however if you tighten it and the drive is almost normal but still weak you do have a worn drive belt
May 10, 2011 | Toro Power Lawn Mower
Gear shift button hard to push
Well the fuse could be the problem but I would doubt that.. Is the button itself dirty in any way? Sometimes the manufactuer just make faulty parts. Has it always done that? Is it just sticking? Can you hear plastic grinding when you force it? I believe it's a problem with the switch itself. Not the operational system of the vehicle...
May 19, 2009 | 1999 Ford Taurus
Garden Logo
83 people viewed this question
Top Weedeater Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
