Question about Magellan GPS
Where is the reset button located on Magellan roadmate 5320?
  • 55 Answers
SOURCE: How to program Magellan RoadMate 1200?
Go to www.magellangps.com. Click on "Support" on the top of the screen. On next page, go to "Product Support and Updates" on the right and enter the "Family" (Magellan RoadMaster Series) and the Model should automatically pop in the box (Magellan RoadMaster 1200 - US). Then, click "Submit". On the next page, go to "Manuals" and select "In English" and click. The manual will automatically start to download. Hope this helps...
Posted on Sep 02, 2008
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
  • 4090 Answers
SOURCE: I was updating my Magellan RoadMate 1470 and the
Here is how to reset your 1340, 1440, or 1470:
Go to the system menu:
On the menu bar ( the top bar where it says Sytem Settings) Tap left corner twice, right corner twice, left corner once, right corner once. It will bring up a hidden menu. The first thing on the hidden menu is reset for first use. Press that and you have done the equivalent of a hard reset.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
  • 184 Answers
SOURCE: reset button for a magellan
Hi allen,
Magellan RoadMate models 1340, 1440, and 1470 are normally reset as follows:
The reset button is located on the right side of the unit. Press a blunt object like a long-shaft ballpoint pen or a cut off toothpick
into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by holding the Power button down for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
Also, here's another procedure you really only try as a last resort, if the unit is on, but acting up with various menus and functions. Use this very carefully...
While on the main Menu Bar at "System Settings", tap the left corner twice, right corner twice, left corner once, and finally, right corner once. You will see a 'Hidden' menu with a "Reset for first use". Press that option and the unit will perform a hard reset. Hopefully, you can continue all you setups from this point.
Also you can download a complete manual from this link:
http://www.magellangps.com/assets/manuals/Magellan_RoadMate_1440_EN.pdf
The manual won't tell you all these little tricks, so it might be a good idea to make a hard copy of these notes (in case you ever need them again...lol). I hope this helps. Please let me know how it turns out, and contact me if you need further help.
Regards, Bill
Posted on Sep 17, 2010
My roadmate 2045 is stuck at a previous location.\r\nwhat can i do?
You can do a reset to this unit by holding the power button for 20 seconds. This should fix your stuck problem
Please dont forget to rate my answers
Jun 17, 2011 | Magellan Roadmate 2045 - uses Gomadic...
Tip
How To Reset Your Magellan Maestro/Roadmate GPS Units
Factory Reset
Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
  1. Locate the button marked "Reset" on the left, right or bottom of the unit.
  2. Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
  3. If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
  1. Remove the Magellan Maestro from the holding cradle.
  2. Hold down the "Power" button on the right side of the device, until the unit powers on.
  3. Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
  4. Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
  1. On the RoadMate, press + + - - + -
  2. The "hidden menu" will appear.
  3. From there, you can access the shell and perform a hard reset.
on Feb 15, 2011 | GPS
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
Turns On but not past the loading screen
Hello :
I recommend you to reset your RoadMate .
To reset your RoadMate please follow these steps :
1: Locate the button marked "Reset" on the left, right or bottom of the unit.
2: Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
NOTE : Please don't attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
This solution should help with your problem . If that didn't help , then I recommend you call Magellan service for help .
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Magellan RoadMate 1340 GPS Receiver
My Magellan RoadMate 1340 will power up to logo and "moving clock
Have you tried updating the software on your device.
Go to Magellan.com and download the Magellan Content Manger:
http://www.magellangps.com/products/map.asp?tab=0&PRODID=2216
Once you've installed Content Manger onto your PC, connect your device to your PC using the USB cord. The Content Manager will allow you to update your 1340 with the latest software and updates which 'should' fix the problem that you're having with your unit.
Apr 04, 2010 | Magellan RoadMate 1340 GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
Magellan roadmate 1412
Try the reset button on the side above the plug in.
Jan 14, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Does not reset location
I too have sometimes to wait for 20 mins before my Roadmate picks up all the satellites it needs. The problem is worse if I'm surrounded by buildings.
I have at last decided to bin the Magellan as it's been nothing but trouble and Magellan Support just don't seem to care to respond.
Am now getting a Tomtom Go series with all preloaded, maps/ traffic/ cameras - it auto updates each time it's put on its cradle attached to PC/internet.
Nov 07, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
57 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
