Question about Bernina Sewing Machines
How to re-align the needle on my Bernina
My sewing machine needle is too far to the left and won't stay centered after turning the machine off and then back on.
SOURCE: Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced.  This is a simple fix and it happens all the time on those machines.  Take it to your local Bernina dealer for a standard service.  Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
Posted on Oct 22, 2007
PABLOCSA
  • 1124 Answers
SOURCE: Trying to sew a buttonhole
You can get all the info of alignments and features of your machine here:
Manual of your machine:
http://www.sewingmanuals.net/bernina-910-sewing-machine-service-man.html
https://www.sew4less.com/product/140/Bernina_910_Instruction_Manual
http://sewingwishlist.com/bernina.html
This information is available online but not for free.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
RickE1
  • 202 Answers
SOURCE: My machine Bernina 830 does not run.
Rose, most likely your machine is gummed up and needs oiling. A product called Tri-Flow is best. It can be purchased at most any hardware store. Or just use normal sewing machine oil. Open the top and put a fair amount of oil down behind the knobs and let it soak in. As it soaks just wiggle the knobs or turn them little by little back and forth until they free up. Don't force anything as something will break.
Good luck
Posted on Nov 29, 2008
SOURCE: Bernina 180 Artista sewing machine
you may have to replace the upper thread sensor
Posted on May 22, 2009
  • 76 Answers
SOURCE: alignment of needle.
make sure the needle is positioned correctly and all the way up into the deedle slot. lower by hand and check again, if still doing so you can tilt the needly slightly befor tightning the screw. lower by hand again an see
Posted on Aug 27, 2009
I have the vintage Brother Riviera 1681, Model F no manual. For STRAIGHT, needle sews only in far left position, but it zig-zags just fine. How do I get needle to middle or right position?
I suspect that the left needle position is the default for your machine. Looking at the photo here, it certainly looks like that is the case. (What a nice looking machine!)
Brother Riviera 1681 Sewing Machine eBay
If you watch this video during the straight-stitch segment, you will see the needle is in the left position.
https://www.youtube.com/watch?v=Qflwon_EVSU
Some of the older machines were made this way--I have an old Nelco that is left default--tough machine, sews almost anything! Unfortunately, if you want a center-needle machine, you would have to buy something else. (Forget about any of the new plastic machines on the market. This Brother will out-sew and outlast them any day of the week.) On the other hand, this is probably a great machine, and once you get accustomed to the left needle, you'll be able to do anything that a center needle machine can do.
FWIW, a sewing machine whose bobbin loads on the left is usually left needle default.
Manual:
http://www.sewingshop.com/1681MANUALPDF.aspx
Jun 21, 2017 | Brother Sewing Machines
How to position the needle
The needle will rise in the holder in only one direction. If you would turn it in any other direction it go up in the holder. Most needles have the flat part in the back or on the right side. Old black Singers is reversed where the needle has the flat part on the left.
Nov 16, 2016 | Sewing Machines
Crazy question but .....how do you center the needle? Always sits to the left
Don't know about your particular model, but maybe left is the normal "resting" position. When on zigzag it will move to the right then back to the left. As long as all of your different stitch patterns keep the needle between the limits of the hole above the shuttle and does not hit the machine bed then I would best guess everything is fine.
Hope that is of some help.
Jan 21, 2016 | Singer 3321 Talent Sewing Machine
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
After interference, the needle won't reposition left or right properly.
sounds like something got damaged or broke & the machine needs to be checked
Mar 24, 2012 | Brother CS6000i Computerized Sewing...
Can't get the needle to go in all the way an stay.what could be the problem?
this question doesn't mention the name or model of the sewing machine
are the needles the correct ones for the sewing machine?
there are certain sewing machine that require only certain needles to used in the machine
or the needle may be turned wrong
the flat side of the needle normally goes to the back of the machine
then it's push up as far as it can go then tighten the screw
Aug 09, 2011 | Singer Sewing Machines
Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Feb 22, 2010 | PfaFF Sewing Machines
I have a new Singer 1507 sewing machine- needle position wrong
Turn the big knob on the right of your Singer 1507 machine so that the vertical stitch line in the center. (Currently your machine most likely has the vertical stitch line to the left.) Don't push your needle manually; you will damage the needle.
Nov 22, 2009 | Singer 1507
Needle postion
If you mean left or right with a straight stitch, then yes. You use the stitch width selector - you will notice a small raised section in 3 locations, they mark, far left, center and far right.
Jan 25, 2009 | Brother XL-3510 Mechanical Sewing Machine
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
93 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
