Question about Kitchen Ranges
La75 long clock need 6volt electric cord and plug
Can't set clock. 12:00 keeps flashing
SETTING THE CLOCK AND DELAY BREW TIME
To Set the Clock:
1.
Plug the power cord into a standard electrical outlet. The clock
will flash on the control panel to indicate that the time has not
been set yet.
2.
Press and hold the HOUR and MINUTE buttons until you reach
the current time. The AM or PM indicator will light at the bottom
of the display (Figure 1).
The clock is now set!
NOTE:
Pressing any button before setting the clock will cause the
clock to start keeping time from 12:00 a.m. You must set the clock
if you want to use the Delay Brew feature.
Nov 01, 2014 | Mr. Coffee 10-Cup OptimalBrew Thermal...
What kind of plug adapter does my recorder take?
you will need a 6v or six volt power adapter to use a house hold electrical outlet. You can use it in your vehicle if your adapter can convert 12 volt dc to 6volt dc
May 11, 2014 | General Electric 3-5027a Portable Cassette...
Hi i have a 6volt kids ride on car i have
I would keep the 6 volt for the control and use 24 for the motor BUT you have to replace the motor with one that is 24
Aug 18, 2013 | Electric Kid Trax C6 Corvette Ride On
Electrical power is off on my Hotpoint 183D6027G069, even though power is on for all other appliances and all circuit breakers checked normal.
I'm guessing this is a gas / propane stove - so the power is likely 120v if in N. America. If this is the case, I would unplug the stove and plug it into another outlet. If none is close enough, you should be able to run an extension cord to determine if it is an outlet or stove problem.
The 120v is needed on gas stoves mostly for lights, electronics, clock, ignitors, etc. It is not for heating / cook of foods so a decent cord should be fine to use. If it still refuses to function on a known to be good outlet, the power outage you had has caused a problem in the stove and will likely require service.
Mar 12, 2013 | Kitchen Ranges
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
How do plug 6volt charger to a 12 volt battery power wheel
Youn can,t do it.6 volt is only for low ampre batttery while 12 volt is for let said cars.
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Dec 28, 2017 | Frigidaire FEB27S5A Electric Single Oven
GE JBP64 Radiant Range - won't work
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker.
Aug 31, 2008 | GE Spectra JBP78 Electric Kitchen Range
Problem with electrical source
Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
Aug 26, 2008 | Microwave Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
