Question about Hilti Drills
Chuck on my hilti TE 15 C has come of ... how do I refit it
  • 152 Answers
SOURCE: hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Posted on Mar 15, 2009
  • 61 Answers
SOURCE: parts for my hilti te 76
If you send me an email i will send you the parts diagram. parts are available from me but I am in Gibraltar. but I can give you a quote if you like.
paul@wysehire.gi
www.wysehire.gi
Posted on Oct 11, 2009
SRF518
  • 232 Answers
SOURCE: grease for hilti te 24
any liquidy grease like lubriplate or milwaukee type Y grease part no. 49-08-5270
Posted on Oct 20, 2009
Testimonial: "thanks doc"
  • 165 Answers
SOURCE: Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Posted on Feb 27, 2010
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
I nide a chuck for a hilti model te 805 chiping hamer
That chuck is not just one piece. If in the U S contact Hilti @ 1 800 879 8000
Jan 20, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Where should I grease the hilti 7c
You should not have to grease The TE-7. It is permantly lubricated. You can occasionally put a small ball of grease on the end of a drill bit before you stick in the chuck. This will keep the chuck greased.
Aug 14, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Hilti te 15-c i have a oil leak behind the chuck.
It depends on where the leak is. if you email me I can send you an exploded diagram of tis machine. This will give you an idea of how to take it apart.
paul@wysehire.gi
Apr 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
How do you change out the chisel on the Hilti TE 76P?
Pull back on the chuck head and turn it. The Chisle should fall out.
Oct 25, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
54 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
