Question about Cameras
Do i need a new battery for y reader - Cameras
  • 12,255 Answers
How would we know this??
Posted on May 10, 2017
Kindle Reader 5th generation. The screen reads :Needs Repair after I changed the battery.
did you buy an original battery or a cheap copy battery. as some cheap batteries don't have the info of the battery, and the kindle uses this to state the batteries voltage and its model number. if this does not have a info on the battery it thinks there is no battery installed..... also have you tried removing the new battery and checked the battery conditions on the board and the battery as the board can become damaged removing the old battery if not done properly
Jan 26, 2017 | Tablets & eReaders
I owen holden cruze 2lt turbo ive replace the battery it runs for about a minute then shuts off wont start again
Hi Did you by any chance have ignition swithed on when you refitted new battery? If so disconnect negative terminal at battery for about 5 minutes all modules will go to sleep and reset (ign off) reconnect battery and try again. If that does not work you will need a fault code reader. It is advisable to connect a fault code reader 1st however as you have already disconnected the battery it has probabley lost any fault codes anyway,Good luck
May 29, 2016 | Holden Cars & Trucks
How do you replace battery in gobii ereader
There are several fora on the net, discussing the battery replacement for the Gobii ereader. It looks as if there is no service for this reader. Some people even say you should trow it away and buy a new reader.
I think it should be possible to open the reader and order a battery, as soon as you can get it out. Just use google to fine a replacement battery.
You also could visit a phone repair shop and ask them what it cost to replace a battery, but first check what a new one will cost, because in a shop it could cost more then a new reader.
Success
Nov 24, 2014 | Tablets & eReaders
Battery replace
I think you can buy only usb external battery charger or portable battery
Dec 17, 2013 | Sharper Image Literati Reader 16375680042...
Where is the user guide for pinsentry
You'll notice there are 3 buttons across the top of your reader or within Mobile PINsentry: Identify, Respond and Sign. They all have similar functions (to verify your identity and protect your accounts) but are used in different circumstances.
satellite?blobcol=urldata&blobkey=id&blobtable=mungoblobs&blobwhere=1260087396572&ssbinary=true
IdentifyIf you've logged in with your passcode and memorable word and are asked to authenticate using PINsentry (for example if you are setting up Text Alerts) the process is the same as logging in.
RespondThis is used if you're registering for Barclays Pingit or any other Barclays apps. The process is similar to logging in - you'll get full instructions when you register.
SignIf you've made a payment to someone new in Online Banking, you'll be asked to sign the payment. The process is similar to logging in - you'll get full instructions when you're making your payment.
Some things you'll need to know:
  • Your card reader is battery powered and does not need to be plugged in. The batteries should last between 5 and 7 years. Audio card reader batteries will last 2 to 3 years
  • Your card reader will time out and turn off after 90 seconds of inactivity. To reactivate the card reader, remove and reinsert your bank card
  • The card reader does not need to be connected to your computer at any time. It works completely independently, based on your card and the information you enter into it
  • Never accept instructions to synchronise the PINsentry card reader - no synchronisation is necessary
  • Never accept instructions from anyone asking you to enter an account number and amount into the PINsentry card reader unless you wish to make a payment to them
Nov 21, 2013 | Computers & Internet
I thought i had a bad battery, so i bought a new one. Upon installation the car would not turn over at all. and the theft system light came on. Could a new battery do that to the car. and where do i input...
yes if battery has gone flat over time ,common occurance and now its a dealer only job also you may even need a new computer because of brown out .
Sep 03, 2010 | 1998 Pontiac Sunfire
Bought a new battery for the 2005 Ford 500. Now with the new battery, the engine and trans lights come on.
Probably when the old battery died as you attempted to start the system voltage went so low it generated random fault codes, you need to locate a code reader and have them read and reset.
Feb 23, 2010 | 2005 Ford Five Hundred
N73 memory card locked
You need a memory card reader to do this.
Turn on your Nokia cell phone.
Remove the memory card from your phone by sliding off the back panel and prying the memory card out of its slot. Place the memory card into your memory card reader.
Create this directory on your memory card reader: E:\System\Recogs. (Note: Here "E:" drive is your Removable drive of the Card, may be F,G,H...) Type the code: thc-nokia-unlock.mdl into your new directory on the memory card reader.
Take the memory card out of the memory card reader and replace it in your cell phone. Wait around two to three minutes for the directory program to load from the memory card into your phone.
Take the battery out of your phone next, which is found under the back panel and near the memory card. Next, remove the memory card again and replace the battery.
Turn your phone on again. Your new unlock code for your phone will be "12345."
If i was helpful, kindly do Rate!
Jul 23, 2009 | Nokia N73 Cellular Phone
My daughter's Leap Frog Tag reader pen will simply not turn on. I bought new batteries nd tried them all. What should I try?!
Hello I will try to help you. If the pen was working up until the batteries died then the problem logically would be solved by putting in new batteries. That said, remove the "new" batteries and install them in another device to be sure that they are good. Some new batteries die in the package before being used.
Then make sure you are putting the batteries in correctly, pay attention to the + and -.
Finally, you can clean the ends of the battery chamber by using a pencil eraser and rubbing it on the metal contacts.
Let me know if one of these things fixes your problem as I have additional ideas.
Jun 08, 2009 | LeapFrog Tag Reading System
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
