Question about Garden
NewHolland T5.115 PTO sometimes will not switch on, as if processor does not recognise it. turn engine off and on and usually pto ok. new switch no change
  • 202 Answers
SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Posted on Jul 19, 2009
  • 153 Answers
SOURCE: When I engage the front PTO the engine dies.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
Posted on Oct 14, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
Engine powered down going up hill then recovered, PTO stopped, now engine will not turn over
safety switch,unhook the ground wire from coil,if it starts then a safety switch is bad,also might need a new ign switch.
Apr 21, 2015 | Garden
Pto does not disenguage when I push clutch pedal in
Normally the Clutch/Brake pedal doesn't turn off the PTO.
If the PTO is running, and you do not lock the clutch/brake in the full down position, when you get up from the seat the system will kill the engine. However, the PTO system is still active.
Thus, if you sit back down and try to crank the engine, it won't crank. You must first turn off the PTO switch.
Based on your comment, you are right, the Clutch/Brake will not turn off the PTO as long as you remain in place (and don't try backing up). If you want the PTO to disengage you must turn off the PTO switch.
Mar 21, 2015 | Garden
Wheelhorse 314 engines dies when pto is engaged
I am assuming you have a manual PTO clutch since you did not mention a PTO switch. The starting circuit generally is a series of switches wired in line (series) with each other. You have bypassed the seat but there is usually a switch for neutral, PTO, oil level, and clutch. You will need to trace the wires from one to the other to find the problem. If the seat has a double switch (3 or 4 wires) it is wired through the PTO switch which may be a double switch to short out the ignition so that part of the circuit should stay open to operate. If the oil level is ok and the oil has been changed as recommended you may better consult a Wheelhorse service person. Bypassing the switches is for testing only! I DO NOT RECOMEND LEAVING ANY SAFETY SWITCH BYPASSED. Any defective or out of adjustment switch should be replaced or corrected.
May 05, 2013 | Garden
Can malfunction of PTO or other safety switches prevent start up of mower
You didn't state the model or brand of tractor, but usually the way the cranking circuit work is, from the "S" terminal of the ignition switch, the circuit runs to the PTO switch, if it's in the OFF position, the circuit then runs to the pedal switch, if it's in the DOWN (or brake on) position it then runs to the solenoid. On other tractors, from the ignition switch, the circuit runs to the pedal switch first. (The seat switch isn't used in the cranking circuit).
Any switch can go bad, but I would more likely suspect the pedal switch or loose connection at either switch. (But it could actually be the PTO switch).
Try tracing the circuit from the "S" terminal of the ignition switch through the PTO or pedal switches to the starter solenoid. You may get lucky and find something obvious.
If you find nothing, try jumping across the pedal or the PTO switch (only two terminals are used in the cranking circuit, trace back to ignition switch for the incoming, outgoing is usually directly adjacent). Jumpering will take these out of the circuit and tell you if either is bad internally.
Lastly, there's always the possibility that the ignition switch is bad. (Doesn't happen all that often, but it's suspect as well). Jumper from "B" terminal to "S" terminal will take it out of the circuit.
Aug 21, 2012 | Garden
John Deere 314 garden tractor PTO mower deck kills engine
bypass the safety switch on the seat to test that one
Aug 13, 2012 | Garden
NO power to pto craftsman gt 5000
could be a clutch switch look at sears parts online for the location
Apr 01, 2012 | Garden
Blows fuse for blade clutch after 20 to 30 secounds ...
Most likely there is an internal short in the PTO clutch, but it could also be in the wiring, which is way cheaper to fix! So, with the engine off, get down on the ground, find the PTO clutch (it's between the two pulleys under the motor) and trace the wires that go to it. Look for a worn spot in the insulation anywhere, especially likely where the wires pass through the chassis or if they've touched a belt or other moving part. If you find a wiring problem, just splice in a new wire.
Ok, if you found nothing, then unplug the connector that connects the wires from the PTO. Start the engine, drive around, engage the PTO switch (of course, the blades won't spin). If the PTO fuse does not blow, you've proven the problem is in the PTO clutch and you must replace it ($150 or so, sorry!). If the fuse does blow, that's good news, you just have a short in the wiring or in the PTO switch itself. Disconnect the wires from the switch to differentiate those two possibilities. The PTO switch isn't too expensive either. Good luck! Please rate my solution if helpful.
Aug 16, 2010 | Husqvarna Zero Turn Mower Z5426
DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Apr 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Jul 16, 2009 | Husqvarna Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
