Question about Minolta Office Equipment & Supplies
Minolta EP 2030 error code C05 how to reset - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,674 Answers
Open the front door with power on in the upper left you should see a small panel remove the cover, press the small switch wait for ready to copy, if the code comes back do not reset the FUSER is bad it can start a FIRE ruining a perfectly good day!!!!!
Posted on Feb 10, 2018
SOURCE: Minolta EO 1080 Copier-Error Code C05
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem.  It will also come up if your power cord is loose.  You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on.  It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
Posted on Oct 15, 2007
  • 57 Answers
SOURCE: EP 1083 service /reset codes
Press on keyboard, stop o stop 1. Press 4 to enter counter mode., the first counter should be the pm, displaying a counter with a negative sign. Press cancel key to reset to 0. Exit service mode by pressing panel reset 2 or 3 times and you should be back in business.
Posted on Jul 14, 2008
SOURCE: meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Posted on Nov 03, 2008
PORRATEC
  • 25 Answers
SOURCE: Minolta copier EP 2030 error code C 04
No, in stand-by the exposure lamp should not switch on. What comes on in regular intervals is the heating lamp inside the fusing roler which can be seen from the exit side of the copies. The exposure lamp is under the glass and only comes on and print button is pressed and copy process begins.
GOOD LUCK.
Posted on Nov 04, 2008
Cogz
  • 1326 Answers
SOURCE: reset button
Are you looking for the Trouble Reset Button? It is behind the top back cover on the Controler PCB, it is a Small BLACK button... Good Luck What code are you resetting?
Posted on Nov 12, 2008
Miolta cs pro 2030 C05
sir/mam Reset button is located behind the copier remove the rear upper cover you see a circuit board with machine on depress the small black button on the board. If the code comes back then the fusing unit the hot part is broke could be thermistor, heat fuse, heat lamp or the board that controls it. Have a tech look at it. DO not continue to reset or a fire can occur that would ruin a perfectly good day :) Code is for the FUSER!!!! (HOT PART)
Mar 13, 2012 | Minolta Office Equipment & Supplies
Spanner reset minolta ep 1054
Feb 06, 2012 | Minolta Office Equipment & Supplies
Minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
C05
Sir to fix will require you to take the rear panel off with the copier on. the upper rear panel once you have it off. Then find the circuit board on it will be a small black button, lower right side. press it. the machine will reset if it comes back your fusing unit (The HOT) part has a bad lamp thermistor, or thermosat. And will need replacing. The code will not clear by powering off then on. or by opening and closing front door.
Mar 10, 2010 | Minolta EP1083 CS/PRO Copier
Meaning of code C04 ( EP 2030)
Nov 15, 2007 | Minolta EP1030/1030F CS/PRO Copier
Oct 13, 2007 | Office Equipment & Supplies
75 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
