Question about Cell Phones
A tip in what Isaw when I entered the tip selection
Oil mixing in the radiator
Sounds like you have a crack in your block and will have to have a new engine.
Oct 01, 2012 | 2005 Buick LaCrosse
Isaw a red ring instead of a green ring when you turn the 360 on!!
Its a common problem.
Try this guide: http://www.squidoo.com/xbox-troubleshooting-red-ring-of-death-fix
Mar 15, 2011 | Microsoft Xbox 360 Console
Can not get psp to connect to wireless router
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Steps Turn on your PSP.
Enable wifi by flipping the WLAN switch to the on position.
Select network setup from main menu, select network settings (press "X").
Select infrastructure mode.
Create a new connection.
Select scan to look for your WiFi network.
otherwise if you know all of your network settings, you can do it maually
Select your wifi networks SSID.
Enter your security settings(if applicable)(WEP, WEP TKIP, Shared Key).
Select "easy" in configure network settings to obtain ip address.
Confirm the settings.
Test the connection.
Go back to the main menu, select the broswer & enter a web address (www.google.com etc.). Your PSP's internet is ready to be surfed out wirelessly.
the psp, unless you have a hack installed, will not be able to browse sites such as youtube, or facebook, or twitter because they require flash/java/enhanced memory[this is not the memory stick]it can however use facebook mobile or myspace mobile by typing in m.facebook/m.myspace.com -- Tips:
  • You may have to do this every time you are in a new area or surrounding that has wifi hotspots
  • Go to www.youtube.com for tips, tricks and hacks.
  • Go to your favorite cheat code website for cheat codes.
Things You'll Need
  • Sony PSP
  • Internet
  • Wireless router
Jun 11, 2010 | Sony PlayStation Portable (PSP) Console
How can I enter a soft (2 sec.) pause in a contact number on A766
1) From the Home screen, go to Start > Contacts
2) Select the desired phone number
3) Press the Menu soft key and select Edit.
4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
6) Use the keypad to enter any additional numbers if desired.
Tip: You can create pauses longer than two seconds by entering multiple pauses.
Aug 01, 2009 | Samsung Propel A767 Cell Phone
I instal cd rom from macintosh in place cd rom for windows
To uninstall the program, click START, Control Panel, Programs, under Programs and Features is listed Uninstall a Program. Select and a list will generate of all your programs. Find the appropriate one and click uninstall.
Feb 11, 2009 | Microsoft Windows Vista Home Premium with...
Norstar M7310 User Manual
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Hope this helps..
Dec 23, 2008 | NorStar M7310 Corded Phone
Activation code
Isaw your post on fixya .com thnx for sending me an e-mail! here's yourcode! ****************************happy playing!!!! can i ask you afavor? can you add me on friendster?? here's my e-mail add****************************
Jun 29, 2008 | Nokia 6600
For add photo
click on my computer it should show removable .... click to open that. then it should show for your photos etc....
May 30, 2008 | Coby MP-C7085 MP3 Player
Nokia
FLOW THE TIPS. SELECT OPEN FLODER > MP3 SONG > SELECT SONG > OPEN> SELECT SONG START TO END > OPEN WAV OPTION > SELECT THE PATH WHERE U SAVE THE WAV TONE > ENTER NAME OF THE SONG > AFTER FINISH PROCESS PRESS OK BOTTON.
Mar 02, 2008 | Nokia 6600
Mp3 problems
format it and start again ?
Feb 09, 2008 | Nextar MA7151B MP3 Player
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
