Question about Tablets & eReaders
I have a iPad and a new charger and it don't charge, I have tried several and I have to move the charger into the port and hold it when the green light comes on that charges it
SOURCE: Power port on le1600 does not charge batteries.
We contacted Motion about an issue with our docking station because our power & USB ports stopped working, or worked only intermittently. We were instructed to remove the front cover from the docking station to check the connection of the cables. We found that the cable had completely disconnected (it had evidently pulled loose from tilting the dock up and down). Once the cable was reattached, and the cover reassembled, viola! Success!
Posted on Nov 23, 2009
  • 84 Answers
SOURCE: Wont charge or keep a charge
First off, a google search will show you several companies out there that will replace the cells in your existing battery for around $70. Not bad. However, you mentioned that positioning of the plug can get it to work. The solder joints can become broken from the board, and the small plug in jack will get loose after a year or two of plugging in to it.
You can get a replacement plug at fry's electronics, or many online stores. If you need a service manual, or driver disk set, you can get them at mpcdrivers.com
Posted on Apr 10, 2010
  • 846 Answers
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
Posted on Apr 26, 2010
  • 104 Answers
SOURCE: i got a ipad for
Most chances are the problem is the cable. You can try connecting the ipad to the pc, if you can connect then the problem is not the cable, but the charger.
You could try to use another cable from a friend with an ipad/ipod/iphone, just to be 100% sure.
Also try moving the cable around, the cable may be interrupted, it happened the same for me with my iphone.
Regards,
katharsys_i
Posted on Mar 03, 2011
  • 4 Answers
SOURCE: Battery was dead. Charged until light turned green. Now have screen that says slide and release power switch to wake. nothing happens. No light and does not wake up. Tried charging again and don'
friend please give a pawor shok to bettery.i think then he started to work.if she not working then please try a new bettery.
Posted on Feb 14, 2012
I would like to get help with this IPAD that the battery will not charge I just got this IPAD today from the seller.
First you have to verify if the charger is working. You can't charge an iPad on an iPhone charger, not a lot of people know that. Do you see the charge symbol? The charger may be weak, check it by trying to charge the iPad on another charger perhaps belonging to a friend. If that checks out, the battery has failed. Apple charges about $130 plus tax, places in the mall charge $90. If it is a used one, they fail after about 3 or 4 years. If it is new, contact the seller. Their reviews are good
https://9to5toys.com/2016/05/31/apple-128gb-ipad-pro-wi-fi-cellular/
Guarantee Cellular eBay Stores
Mar 22, 2017 | Apple iPad Tablets & eReaders
IPad will not charge even though battery and charge port both replaced.
Incorrect port part, Wrong polarity for wires connected to the port or poor connection of wires to the port.
Nov 30, 2015 | Apple iPad 64 GB 3G Tablet PC
Why doesn't my iPad mini turn on or charge?
possibly the internal battery has failed you
Nov 20, 2015 | Apple iPad Mini
What do I do if my android tablet stops charging
If you have tried different chargers and still can't get it to charge, then it sounds like the charger port may have physical damage. You can also do a hard reset by holding in the power button for thirty seconds then turning it on agin . Try several times. Also inspect the charging port for lint or dammage.
Oct 14, 2014 | Tablets & eReaders
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Jul 26, 2014 | Apple iPad 32 GB WiFi Tablet PC
Ipad will not start?!
There are a few things to try. 1) Press the power button and the home button (on the front) at the same time. If that doesn't work 2) try plugging it into a different charger than you normally use. If that works, you need a new charger. If it doesn't show that it's charging within 30 seconds, your iPad charging port or battery probably has a problem and will need repaired.
Jun 25, 2014 | Apple iPad 32 GB WiFi Tablet PC
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Mar 27, 2012 | Apple iPad HD
the ipad will charge with the charger that comes with it
if you want to charge it with the cpu you have to turn off the ipod before it will charge
Press and hold sleep /wake button
til it says slide to power off
Feb 11, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
42 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
