Question about Coffee Makers & Espresso Machines
Makes coffee crusinet put won't drain into cut
Spring release is not working to let the brewed coffee drain into the cup
SOURCE: One year old coffee maker won't brew
This is my second dcc-2000 with the same problem. I tossed the first one and in less than a year the second one exhibits the same issue. I called the Customer Service (1-800-726-0190). The rep told me to unplug the unit for at least 2 hours adding that this would let the system "reset itself". He then instructed me to run vinegar and water through it to clean the pumping system. I am doubtful about this solution but the rep assured me it would be replaced if I still have problems. It's worth calling CS to get it replaced, however, it seems that this model is flawed by design.
Posted on Aug 21, 2008
  • 12 Answers
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Posted on Dec 27, 2008
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Posted on Sep 30, 2009
We have a Burr Grind & Brew 12-cup, programmable Cuisinart. Even with the vinegar solution, it seems to clog more than we expected. We have a water softener. Tired of making 8 cups and only getting 5...
you must physically remove the lime.
first remove the spray head and then brew the coffee in an empty waste container.
remove all the lime as much as you can.the hot water force the lime to go out .
please rate my work
Sep 05, 2011 | Cuisinart GRIND AND BREW COFFEE MAKER
How to calibrate a Bunn CWTF commercial coffee brewer
1. you need a 64 ounce graduated measuring cup or bucket
2. make sure the brewer is heated up to temp and the green light on the front is lit
3. open the front panel of the brewer
4. put the microswitch on the circuit board to "unlock" position
5. make sure the sprayhead is cleaned and open, the brew basket is on, and the measuring cup is in place to catch the water
6. press and hold the brew switch until the inlet solenoid clicks 3 times, then release
7. once the water level is at about 40 ounces, turn the main red switch off and let the rest of the water come out
8. if it brews short, press and hold the brew switch again until the 3 clicks, then press and release the brew switch for 2 more second of brew time (up to 5 times per brew)
9. if it brews too much, press and release the brew switch for two less seconds of brew time (up to 5 times), then press and hold the brew switch until the 3 clicks then release
10. once you get to 64 ounces, put the switch on the circuit board to lock and replace the panel
11. enjoy!
on Jan 15, 2015 | Bunn CWTF 15-APS Coffee Maker
It won't brew when it says its brewing. Why won't it brew my coffee? Just seems to be really slow and I have only had this coffee maker about a year.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Aug 18, 2011 | Keurig Platinum B70 Coffee Maker
Cuisinart grind and brew pot - door holding filter pops open during grinding/brewing.
There is a little cover over a spring. The loops of the spring go inside the screw that holds the cover. The spring ends are against the wall and a small pin connected to the button on the side. Keeps the button locked. Cleaning out dried coffee in the are may help and pam spray may keep it from sticking.
Oct 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
Check the following:
1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Jul 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
