Question about Microsoft Wireless Laser Mouse 5000
The keyboard stopped working although it appears that it is sufficiently charged asnd the signal quality is high.
  • 2 more comments
  • andreapowers Jul 25, 2009
    The keyboard was working fine and then I brushed the keys with a cloth and I am thinking I locked it some how. I have turned off and restared the PC and also reconnected the receiver. Still no juice.
    my microsoft 5000 laser keyboard stopped working after I brushed the keys accidentally. I have restarted the PC and unplugged and replugged the receiver. The signal is good and the batteries are good
    i will try it.
    where is the optical lens on this keyboard??
  • 1,555 Answers
I would suggest you to take out the batteries of your keyboard. Take a vaccum cleaner put the vaccum on medium blow and dust the keyboard from bottom side while keys facing towards the ground i.e. anything between the keys shall fall on the ground shall not go inside. wait for 2-3 minutes put the batteries in again and try using your keyboard. Also look for any physical damage on the optical lense.
Posted on Jul 25, 2009
  • Aruna Singh
    Aruna Singh Jul 25, 2009
    It must be a small rectangular semi transparent black plastic thing through which your keyboard broadcasts its frequencies for your receiver to receive.
    Genius:
  • 1,341 Answers
Check battery and restart computer.Try to reset the keyboard and the receiver.They normally have a small connect button on them that you need to mess with before it works.Check all other cable connections from receiver to pc,change batteries if needed and make sure keyboard is within range distance to receiver.If this does not solve this then you have a faulty equipment here.
I have code p0573 saying brake switch A is high although brake lights are working ok, can anyone help please
Possible causes
- Faulty Brake Switch
- Brake Switch harness is open or shorted
- Brake Switch circuit poor electrical connection
help.jpg What does this mean? When is the code detected?
The P0573 codes is set when the stop light switch signal is too high.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Stop light inoperative
- Cruise control system inoperative
P0573 Description
When the brake pedal is depressed, the stop light switch sends a signal to the Engine Control Module (ECM). When the ECM receives this signal, it cancels the cruise control.
Aug 29, 2014 | Cars & Trucks
1011 keyboard
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem.
If you can't solve the problem, you need to replace the asus eee pc 1011 keyboard. we supply high quality and low price asus eee pc 1011 keyboard.
May 09, 2013 | Computers & Internet
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
What is the maximum length we can go for HDMI connection with loss of data?
There is no declared max length, although with all wires there is signal attenuation so using higher quality cables will get you better signals at longer lengths. You can also get extenders you can hook in between cables to regenerate the signal so you dont have to break the bank on the really high end cables
Oct 03, 2011 | Computers & Internet
The batteries keep going flat in my HP remote keyboard. The original batteries lasted about 12 months .When a notice appeared on the screen saying the battery was low i replaced them now they only last 2...
you might want to try quality batteries. When you replace the batteries let the keyboard set with no batteries for e.g. 5 minutes so that it "registers" that the batteries have been replaced. Maby disable the onscreen message and just use the keyboard untill it stops working :-)
Regards.
Apr 02, 2011 | Compaq Keyboard
Yamaha keyboard not working
We have a Yamaha keyboard YPT-330 note E and F sharp not working why?
Feb 25, 2010 | Yamaha Music
My TomTom XL1 at times will not pick up gps signal. Note comes on and says lost GPS signal 2.4 min ago.
your battery is beginning to fade. if you fully charge it before use asnd it does this regularly then replace the battery
Jul 24, 2009 | GPS
CLEAR PICTURE ON MY 42
Dear LADY DAWN,
In order to get true high definition quality, you would want a high definition source. There really is not much else you can add to make your picture clearer, provided you have it hooked up with the best type of cables possible.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jul 21, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Microsoft Wireless Laser Mouse 5000 Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
