How can I stop my TVs from automatically swapping to kids tv at the same time everyday? It's like someone has set a reminder but cannot see how to take it off
Mitsubishi tv model WD-65731.replaced lamp worked a few days.Now turn on timer lite flashes it will kick on all i get is sound or the red lamp lite comes on & the tv goes off.can someone plz help me?
Hi I wish I could think of the name of what is going on it is so simple for a TV repairman under a hundred bucks I'm not kidding when I say this they prefer to work on projection TVs any day of the week then these new LEDs and bl get ahold of somebody local TV repairman. Cheap, easy for you. I said to people threw out perfectly good projection TVs when all it was was under $100 fixed and that including the man coming to my house.
Nov 06, 2016 | Mitsubishi WD-65731 65" HDTV
How do I set the alarm on my alcatel one touch tribe 3000G? I only want it set for one day per week. I can set the time and bring up "once" but the days highlight as 5 or 7 days
I'm afraid the alarm feature only works for weekdays (5) or everyday (7).
But you can use the Calendar and create events at specific dates with "alarm" reminder.
Nov 24, 2014 | Alcatel Cell Phones
My toshiba tv turns off by its self everyday at 4:30 am how do i stop this
Check your settings, you may have time set to turn off at this specific time. Uncheck this setting or set to value 0.
Hope this helps
Apr 19, 2014 | Toshiba 62HM195 62 in. HDTV DLP TV
My LG Plasma TV 42LH50YD turn off by itself after about an hour it turn on by the schedule time on. it happens once everyday around the same time. My TV is connected to a PC which schedule to restart...
Ty a factory reset to this TV; and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 25, 2017 | LG 42LH50 42 in. HDTV LCD
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
My RMF-GD001 operates everything except the tv. I own a Sony Bravia XBR46-45 tv connected to a sony surround sound system
I had the same problem.
My Bravia LCD TV wasn't responding to its remote RMF-GD001 although the remote works on the home entertainment unit. Lucky for me, I have an extended warranty and so I called for a service. Technician tested my remote and said that it's RF transmitter is spoilt. Little did I know that the remote has IR and RF transmitter and it will work on any devices that uses infra red transmission. But Bravia LCD TVs use the radio frequency transmission and that is where the problem is.
I had my $125 remote replaced FOC. :)
This reminds me to get a silicon case for the remote and to put it out of reach from my kids who like to drop things.
Oct 18, 2011 | Sony Televison & Video
RCA tv/dvd combo model # D52W27D. I am having similar problems with the front green light blinking 3 times but mine doesnt come on. I cannot open my dvd player or anything. It sounds like it trying to come...
Sounds like your power board has issues and needs repairing or replacing, if your tech savvy you can repair it but it might make more sense to order a new one, this board is known for issues in tvs like you have
Feb 09, 2018 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv automatically changes format
buttons on the facia of the TV, or the buttons on the remote?....
If it is the buttons on the TV...
Do you have kids? Sounds like someone has spilled something down behind the little PCB behind the buttons on the TV... either that or the little ribbon connector attached to that PCB is boogered up.
Mar 13, 2009 | Mitsubishi WS-55313 55" Rear Projection...
Won't stop ringing
Well, I doubt it's the phone but just to make sure, swap phones around and see if the problem stays at the extension or moves with the phone. I am not familiar with the timed reminder feature but that certainly does sound suspicious... Have you used this feature before? Does it make your phone ring? There may be something special you need to do to answer the timed reminder and make it go away. Possibly canceling the timed reminder was too late after it was set off.
Sep 14, 2007 | Panasonic KX-T7730 Corded Phone
Changed settings
Press and hold the Stop button on the DVD player itself it should reset back to factory settings
Sep 08, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
Top Televison & Video Experts
