Question about Water Water Heaters
Caravan truma hot water container how do you change all seals on hot water tank
2 Suggested Answers
  • 6 Answers
SOURCE: no water coming out of hot water taps, water is
I'm not sure I have the whole picture here but When water simply will not flow from a tank your first guess that it is a faulty valve was a good one. While you had the valve off did you turn on the water briefly to verify that it flows well at least up to where your valve was? You may have to do this test. The clog could be right at the tank itself. Before you open up the pipe again first look for anything steel. I have found steel plugs screwed into an old threaded outlet on a pipe that has, over time, produced a large rusty blob that has blocked the flow of the water. If there is nothing like that going on you will have to open up the pipe. By the way, if hot water flows at any other locations, like the tub, then you know that the problem is not at the tank. you have to figure out where the blockage is by a process of elimination.
Posted on Jun 16, 2009
Can I use a Truma hot water heater on gas in my shed kitchen for washing up?
I just looked on the website which contains a remark there is only approval for installations for campervans and caravans.
Nowhere in the description or specifications does it mention a flue or ventilation requirement which is very surprising because burning gas needs a good supply of fresh air and produces poisonous gases that must be got rid of/vented to the exterior.
I guess you could use your heater as long as the requirements of an adequate fresh air supply and the venting of combustion gases is taken care of...
Sep 10, 2017 | Water Water Heaters
Truma Ultra store water heater. How ti hard wire from 230volts. Many Thanks awaiting reply ?
There may be a wiring diagram pasted somewhere on the heater. If not, request the diagram directly from Truma.
Aug 27, 2017 | Water Water Heaters
Truma water heater water wont come out of the taps when on gas, 12 volt or mains 240 volt
Bleed your propane system by running the stove for a sec. if that doesn't work go out to the heater and listen for the ignitor clicks see if it's trying to lite. My fifth wheel does this first time every season.
Feb 22, 2015 | Water Water Heaters
Truma hot water system keeps flicking the circit breaker please help
If this has worked in the past check all the electrical connections and be sure they are tight. You might consider changing the breaker as excess trips tends to lower the trip point. Check the heating elements and be sure they are isolated from ground if not replace them.
Nov 29, 2014 | Water Water Heaters
Carver cascade 2 No water at all comes out of the hot water outlet. The inlet non return valve has been changed & is working correctly.
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Oct 06, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
WHEN MY WATER TANK IS COLD AND I TURN ON THE HOT WATER TAP THE WATER FLOWS FREELY BUT IF I HAVE THE ECONOMY 7 ON OVER NIGHT THE TANK GETS HOT BUT NO WATER FLOWS OUT OF THE TAPS. I LIVE IN A HARD WATER AREA
You may need to replace the tap.hot water is causing the valve to expand and yours may be using a rubber seal inside which is causing expansion and hence no hot water is allowed through it..Trust me on that..
Aug 27, 2009 | Water Heaters
Hot water tank shuts down after5 minutes pilot still on water
Carefully catch some water in a container from pressure relief valve (pull lever slightly) at top of tank, and see if it's up to temperature. If it's hot there, I suspect your by-pass at back of the tank, is faulty. Depending on what by-pass system your using, it may be in wrong position, blocked, or mixing hot and cold. Cold water flows into bottom of tank, and hot out the top. If any valve in between the 2 lines, close it, and make sure valves in and out of bottom and top are open. Let me know what you find, or if water from pressure relief valve is not hot either.
Jul 12, 2009 | RTO Atwood Water Heater - 6 Gal LP
No water coming out of hot water taps, water is getting hot in the tank, we have changed the non return valve it izs a cascade 2 that is whot it says on the outer cover of the caravan
Jun 16, 2009 | Water Heaters
Electric water heater will not stay on
sounds like the electrical thermostat is defective and is being over ridden by the overheat safety stat.
Nov 17, 2008 | Water Heaters
Water Heaters Logo
47 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
