Question about Formula Computers & Internet
HOW TO GET A MULTIPLICATION FORMULA FOR EXCEL?
  • 4 Answers
SOURCE: computer
Any formula in Excel starts with the equals sign ("="). This is how Excel distinguishes between formulas and literal values. Knowing this, you can create lots of formulas using the usual operators of +, -, * and / for addition, subtraction, multiplication and division, respectively. Please see the examples below.
Add 1 + 1: =1+1
Add the contents of cell A1 to the contents of cell B1: =A1+B1
Subtract 2 - 1: =2-1
Add the contents of cell A1 from the contents of cell B1: =B1-A1
Multiply 1 times 2: =1*2
Multiply the contents of cell A1 times the contents of cell B1: =A1*B1
I hope this resolves the question. If not, please let me know.
Posted on Aug 08, 2008
  • 477 Answers
SOURCE: Excel formulas
hello
yes it is.
example
sheet1
A1 (50)
A2 (50)
sheet2
(A1)=
"=Sheet1!A2+Sheet1!A1" <-this is the actually code in sheet2 column A1
ok let me explain
in A1 and A2 in sheet1 you got 50 and 50 like numbers.
in A1 on Sheet2 you have = sheet1 a1 + sheet1 a2.
did you get it?
dont know else how I should explain it...
good luck
Posted on Oct 09, 2008
usmcrave99
  • 69 Answers
SOURCE: formula for copy multiple cells at a time
You'll want to use the IF formula, its syntax goes like this: =IF(condition to be met,value if true,value if false)
If you want to use text for the true/false values, you'll need to put the term in quotes.
Example, lets say you want to know if 260+G$2+F60+$X$99+$A25 is equal to 1024, then the formula would be: =IF(260+G$2+F60+$X$99+$A25=1024,"True","False")
Posted on Dec 30, 2008
JackHeath
  • 1049 Answers
SOURCE: i want the all excel formulas
You will never find a fully comprehensive list anywhere because there are literally hundreds in the basic Excel application and thousands that can be added in as you go via macros. More are being added every time a new version of Office comes out.
But, the easiest way however to get a basic list of functions if your not printing is to hit the function button and simply scroll down the list. The syntax (an example of the method by which you should be formatting the formula) and a definition will list in the bottom of the dialog as you select each function.
That said, you are better solving individual problems as you learn Excel then trying to memorize all the functions themselves. Many, such as mathematical operations are common sense anyway.
Posted on Jun 19, 2009
danilomanjr
  • 45 Answers
SOURCE: Want to copy formula into multiple excel sheets
why not? however, you can also insert an apostrophe (') at the start of the equation before copying the entire formula so that the formula will be treated as a text thus preserving all cell references. dont forget to remove the apostrophes after you have pasted them though for the formulas to work again.
Posted on Aug 08, 2009
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
Formula
check this link it will help you to learn excel
http://people.usd.edu/~bwjames/tut/excel/
dont forget to rate ^^
Jun 08, 2010 | Microsoft Office Professional 2007 Full...
Jul 29, 2009 | Computers & Internet
Wanted to learn "ALL" formulas of MS Office Excel - please guide
Ist I want to know what type of formulas u use in works
Jan 13, 2009 | Computers & Internet
BASIC EXCEL FORMULA
Are you looking to solve any particular problem?--- because there are a huge number of possible formulas in Excel.
However, in my opinion, the most commonly needed ones are addition, subtraction, division, multiplication, and summing.
Suppose you have the following numbers typed into your Excel spreadsheet:
columns: A B C D
rows
1 20 3
2 10 4
3 15 2
4 1 2 3
Then suppose you type in the following formulas (in the D column):
columns: A B C D
rows
1 20 3 =A1+B1
2 10 4 =A2-B2
3 15 2 =A3*B2
4 1 2 3 =sum(A4:C4)
Then the following answers will appear in the D column:
columns: A B C D
rows
1 20 3 23
2 10 4 6
3 15 2 30
4 1 2 3 6
Sep 29, 2008 | Microsoft Computers & Internet
I need Excel's Furmula's
I found some excellent links to excel formulas for you:
This link lists excel formulas by category:
http://www.techonthenet.com/excel/formulas/
This link has some custom formulas for excel that you can download:
http://www.ozgrid.com/VBA/Functions.htm
Sep 20, 2008 | Microsoft Computers & Internet
Computer
Add 1 + 1: =1+1
Aug 08, 2008 | Microsoft Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top Formula Computers & Internet Experts
joegood
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Formula Computer and Internet Expert? Answer questions, earn points and help others
