Question about Savin Office Equipment & Supplies
Sc 552 savin/ricoh
I have a Savin 8065, i replaced the cleaning web and now I am getting the code 552. Not sure where to go next.
drichards
  • 87 Answers
SOURCE: Savin C3030
SC 553 is a fuser overheat error. If you have a fuser great, but you will still have to reset the code. Clear modes, 1, 0 ,7, press and hold clear/stop key. Menu will change, select copy sp. From there, select 5, (mode), scroll till you get to 5810. Select it, and press execute, then exit back to copy sp. Select 7 (data log) then scroll until you get to 7807. Select it, and press execute. Exit all of the way out, and recycle the power.
If it comes to ready, great. Try it. If it codes out again, you have a problem, possibly thermisters, (in the fuser), power supply getting stuck on, I/O board not regulating the power supply. Could be any of these things.
But start by resetting the code. Could be a a thermister got some toner stuck under it, and the other thermister detected a difference. It really could be that easy.
Posted on Mar 12, 2008
mastersaintx
  • 928 Answers
SOURCE: Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Posted on Aug 18, 2008
  • 32 Answers
SOURCE: Savin C6045(Ricoh C3260) popping SC400 and SC496
either the id sensor is dirty or defective, or the music sensor is defective.
Posted on Apr 02, 2009
  • 990 Answers
SOURCE: Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
Posted on May 29, 2009
Matt_Sr
  • 31 Answers
SOURCE: I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Posted on Jun 19, 2009
How to set the error code sc 672-11
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/49446-sc-672-mpc300.html
Mar 22, 2017 | The Computers & Internet
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
What's your problem?error code SC552 on ricoh savin c4540
fusing thermistor error, clean, replace the thermistor
Oct 31, 2011 | Savin Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
Jun 02, 2009 | Ricoh Aficio 450 Copier
29 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
