Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
What type of oil to use when changing oil
What type of oil
    President:
  • 1,273 Answers
For any four cycle engine (engines with separate oil and fuel fill locations) use high quality detergents in the following viscosity.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
(From the MTD answer pages). Best regards, --W/D-- Please feel free to rate my solution. Thanx.
Posted on Jul 25, 2009
Can hydro oil be changed and what type oil on Swisher ZT2460 mower?
yes hydro oil can be changed and should be at regular intervals, the manual should tell you how often and the type of oil to use for best lifespan.
good luck.
Jun 28, 2014 | Swisher 60" 26 Hp Zero Turn Radius Riding...
How often should I change my 454's oil?
Go with the schedule oil change as listed in the hand book. Otherwise 10.000 klm or 6 months . Change at 5000klm if difficult conditions. Type of oil Conditions dictate if you use a multi grade 10/15w- 20/30/40/50 grade oil Again check the hand book Mineral oil will do just a good a job as the more expensive synthentic types As to brands that is you choice.
Mar 10, 2013 | Cars & Trucks
What type of oil do I use for a 1993 Honda XR 250? How much oil do I put in it?
I use semi-synthetic 20W50 and change the oil every 3500-4000 km.
I do the filter at the same time.
Oct 09, 2012 | 1993 Honda XR 250 R
In changing 2005 Harley Heritage Model FLSTCI fork oil, how many ounces of fork oil should I use? What does wet or dry mean?
I'm sorry but I don't have the specs on the quantity and type of fork oil for your year and model bike. I work on the older bikes that the dealers will no longer service. But, I can describe the difference between the "wet" and "dry" conditions of the fork assembly. If you take the front forks apart, clean them out, and put them back together with no oil in them, they are considered "dry". For a simple drain and refill type oil change on them where you don't get all the oil out of them, they are considered "wet". I hope this helps, You can call you local dealer's service department and they should tell you the quantity and viscosity of the oil that goes in the front forks on your machine. They'll tell you something like 6 ounces of "Type E" oil, for example. Harley-Davidson uses these types of specs to describe their oils. If you go to a website for fork oil, like PJ1, they may give a cross reference or equivalency chart for converting H-D "Type E" to their oil. I think that would be their 30 weight oil. If the front end seems too "stiff" with 30 weight, you can drop down to 20 weight. I think Honda makes a 25 weight but not sure. Your Harley won't mind the Honda oil. BG.
Good Luck
Steve
Aug 23, 2011 | 2005 Harley Davidson FLSTC - FLSTCI...
I just bought a '02 Jeep Grand Cherokee and the oil press. indicator is always on H. I heard the engine during idle making a "clancking" sound which i heard before in cars with the wrong oil type...
I would recommend changing the oil and filter, using the correct oil. It's possible the wrong oil could cause the noise. Wait and see if the oil change has any effect on the oil pressure reading. If it doesn't, change the oil pressure switch or sending unit.
Dec 31, 2010 | 2002 Jeep Grand Cherokee
How often should oil be changed ?
That depends on the brand and type of synthetic you use, as well as the type of oil filter. Mobil 1 makes an extended service full synthetic, which they claim is good for 15,000 miles between changes. Amsoil full synthetic advertises 25,000 miles between changes; but only if you also install and use one of their super fine bypass oil filters, in addition to your car's regular oil filter.
Since the actual mileage you can go between oil changes is very dependent of the type of driving you do, the brand of oil you use, and the condition of your engine; there really is no hard and fast rule. That's why commercial vehicle fleets regularly take samples of their oil, and send it to laboratories for analysis to determine whether it needs changing. Sometimes it is necessary to change oil more often than expected; other times you can go longer between changes. My experience has been that, when oil is nearing the mileage where it needs changing; the rate of consumption will significantly increase. So when my car needs a quart added, it usually means it ought to be changed.
Regardless of the oil you use; if the change intervals are longer than the car manufacturers recommendations, it will void your factory engine warranty. That said; I have typically felt comfortable with 7,500 mile change intervals when using full synthetic oil of an appropriate viscosity.
I would also add that it is much safer to stay with only one brand and type of oil for the life of your vehicle; this is true for both conventional and synthetic oils. I have seen too many engines ruined by switching to a different brand or type of oil. Mobil 1 is chemically different from all the other synthetic oils, and is closer to petroleum oil in its characteristics. I prefer it for that reason. They also make a european formula 0W-40 full synthetic, which is available in the U.S, and is my preferred viscosity for all around use. It is not one of their extended service oils; but the protection is far superior to other oil grades. Not all stores carry it; but it can often be ordered from stores which carry other Mobil 1 products; and can always be bought from the local Mobil oil distributor.
Sep 13, 2010 | 2004 Lexus SC 430
What oil type to use when changing engine oil in a c50 boulevard?
Standard oil to use id SAE10W30 or SAE 10W40.
If you are still in doubt go to your local motorcycle dealer and ask the question as the normally are willing to tell you the oil type for your particular bike. Good enough?
May 21, 2010 | Motorcycles
For a honda 125 cbr how often do I change the oil and what type does it need?
oil change: every 1000km
oil type: silkolene comp 4 10w/30
quanity oil: 1000mls
Nov 03, 2009 | 2005 Honda CBR 125 R
I need to change my oil what type of oil do I use?
Look in the owners manual that's in the glove box, that will show what type of oil to use.
In case you don't have one
Moderate climate----- 5w/30
Hot climate----10w/30
Oct 01, 2009 | 2007 Chevrolet Tahoe
Car won't start after oil change jaguar S type
Sounds like overfill oil pressure too high. Oil level is critical. Engine can be damaged.
See my Solution for oil change.
Jul 10, 2009 | 2001 Jaguar S-Type
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
639 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
