Question about Refrigerators
ON MY TWIST AIR REFRIGERATOR - THE TEMP CONTROL DIAL IS 1 TO 9 WITH THE 5 IN THE MIDDLE. IS 1 THE COLDEST OR IS 9? THIS REFRIGERATOR KEEPS FREEZING MY FOOD!
  • 822 Answers
9 should be the coldest.........
chers
Posted on May 10, 2017
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
Food in the fridge part keeps freezing even with setting at highest temp
if its at the highest setting, i.e., the largest number or letter, you have it at the COLDEST setting, and it will freeze in the refrigerated secion. Reset all controls to normal, which is the middle setting. so if your scale range is 1-9, middle setting would be 5, if scale is A-E, middle is C and so on.
After you reset controls, it will take 24 hours for temps to balance themselves out. Your food may take longer to thaw out, so dont go buy whether food is still frozen, instead place a thermometer in the center of the fresh food side. your fridge temp should be in the 35-40°F range. If after 24 hours your fridge section is still below 32, Then you do have a problem, but LG is not a simple unit to diagnose, impossible to do without inspection.
www.FixMyFridge.net
Mar 08, 2010 | LG LRSC26925 Side by Side Refrigerator
Welbuilt Refridgerator (old) - Which way is coldest - 0 or 6?
Most controls work with the highest number being the coldest. Keep in mind that once you adjust that setting you should allow 24 hr for the refrigerator to "equalize" to it new set temp. Hope this helps
Sep 09, 2009 | Refrigerators
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator side is freezing contents
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
With the BevAir DW49 does a lower number mean colder or warmer?
1 is usually the warmest setting. The higher the number to colder the setting. Start in the middle and make minor adjustments allowing considerable time in between to dial in the temp of your unit.
Dec 04, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Frigerator is freezing.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
Beko LF320 temperature dial numbered 1 to 10 which way is coldest?
Right to the point people. ok to make it warmer, it is the lower the number
thanks and go night ;)
Oct 01, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
