Question about Cameras
My back up camera only shows the bars and no actual picture of whats behind me
  • Cameras Master
  • 5,067 Answers
Maybe you keep backing into bars ?
Posted on May 10, 2017
Why is display information having a ghost like after image when the camera is turned?
Perhaps some moist came behind the glass? perhaps some air? Try to live with it, because the result is what counts and the pictures don't have this problem. I think it will cost far to much to bring it to a service or repair centre. Use the money to buy a new camera what this no longer shoot pictures.
May 18, 2014 | Fuji Finepix S3200 14. Mp 24x Wide Angle...
I don't know how take a picture?
It's actually a lot easier than you'd think. You don't tell us what kind of camera you've got, but here are some general tips for beginners:
1. make sure the camera has charged batteries in it, and a memory card.
2. find the power button. It's probably on top, near the shutter "take a picture" button. Press and hold it until the camera comes on. It should show you the current 'view' on the screen.
3. If there's a selector dial on the top... turn it to the green one; that's 'easy shooting'.
4. fully press (squeeze) the button. Most kids who moan that 'it didn't take' it's because they only half pressed it. When it takes, the display will show the picture for a few seconds, before going back to the live view.
5. to see your picture, find a button that has the little triangle icon pointing right, like a 'play' button.
6. to go back to taking pictures, press the shutter button again
7. to turn it off, press the power button until it turns off
If that doesn't work for you, tell us what kind of camera you have. That'll make it easier (just a bit!)
Mar 26, 2011 | Cameras
Describe your Panasonic PV-GS35 Mini DV Digital Camcorder Problem: When I turn the camcorder on in the video camera mode the lcd panel and th evf show black, it does not show current picture to record. All...
There was an earlier post that explained the black ribbon between the LCD viewfinder and the body of the camera is split. You would have to buy a new LCD viewfinder for about $90 or send it back to them to fix for around $250. The same thing happened to my camera and I can actually is the split. If you close it down more than half way the picture shows up. I called Panasonic and they said you have to buy the whole LCD, that you can't just buy the ribbon. They don't even have a part number for just the ribbon. Good luck.
Oct 18, 2009 | Panasonic PV-GS35 Mini DV Digital...
Picture Doesnt Show Up!
Sorry, but this camera does not work that way, you have to actually use the viewfinder.
Jun 07, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Logitech webcam
Are you trying to use more than one application with the cam at one time?
Dec 29, 2007 | Logitech QuickCam Express Web Camera
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
Battery meter
Give a cleaning to the contacts of the camera in the Battery chamber.
Look for the contact plate in the battery cover.
Look in the film pressure plate in the back door,and check its position or look for any dirt between them.
Then you have to check the drive motor.
Oct 11, 2007 | Canon EOS Rebel G 35mm SLR Camera
Not working
When you say 'Get the pictures' Have you actually or can you - down load them to the computer. If you can then go to menue and delete all the pictures. If the memory is full you have yo get those images off.
Jun 01, 2007 | Fuji FinePix F700 Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
